Massey 4707 power
   / Massey 4707 power #1
B11lefevre
Massey 4707
I’ve had a Massey 4707 deluxe 4wd open station with loader for a year now. I primarily use it for raking and tedding hay. I really like the tractor especially the loader lift capacity. The biggest thing I hate is the lack of power. It is completely gutless. I also have a 5310 John Deere which is about the same pto hp. It is lighter and a smaller frame but seems to have a lot more power. I can’t even go up a little incline running a 6 basket tedder. Is this just what it is? It will be out of warranty in the fall so I will probably tune it. I just wanted other people’s experiences. Thank you.
   / Massey 4707 power #2
i am looking to buy a mf 4707 like yours. am disappointed in your tractor hp. anything else to report about your tractor dislikes. thanks tommy
   / Massey 4707 power
I do like the transmission and reverser. I also like that it has DOC for emissions and not DPF and or DEF. At 50 hours it went back to the dealer for an engine oil leak. It ended up being a loose bolt on the front cover. The 3 point hitch didn’t work properly either. Apparently they had to reprogram the computer. Now when it’s cold and you lift the 3 point hitch up the relief valve doesn’t function properly so it stalls the engine. If I keep the rpms up it doesn’t allow the loader to function until the relief valve functions. I hate to say it but I wouldn’t buy one. I have a Deere 5310 and 5510 and a Kubota m105s. All of them with power reverser transmissions and have at least 2000 hours and I haven’t had any issues with any of them.
   / Massey 4707 power #4
I have an older MF 2660 using the Perkins 4cyl rated 81hp . It tested 90hp on a dynamometer when new. No mods. Lack of power was never an issue with it. I am pretty sure the engines on the 4708/9/10 are all the same engine in the newer 3cyl variety. With differing chips or settings to produce more HP on the higher numbered models. That was the case with older ones. Depends what you want and what you are willing to do. If you like the tractor a lot, go find a diesel hotrod shop that specializes in souping up pickup trucks. There seem to be many of those shops these days. I suspect they can get you a whole bunch more HP if you are willing to take the risks. You can talk around and explore those possibilities before your warrantee expires this fall and then decide what to do.
   / Massey 4707 power #5
Can't even go up a little incline with a 6 basket tedder !!?? That's crazy. You mean geared down or just not running as fast and easy as you want to ? Geared down you should be able to climb one heck of a hill not just a little incline.... Your brakes locked on ? (I'm kidding.) Something is wrong here.
   / Massey 4707 power
3 or 4 mph that’s it. I usually go 6-7mph. It’s rather pathetic.
   / Massey 4707 power
Up the hills. On flat ground it’s fine.
   / Massey 4707 power #8
Somethin's wrong.
   / Massey 4707 power #9
My 4707 cab has plenty of power for hills, that's all I have here in WV. But, I am quite disappointed in the couplers they used from the rear of the tractor to the loader valve. They consistently blow orings, leak tons of fluid..
   / Massey 4707 power #10
Say Wacky -- that blowing hyd connector o-rings for lines head to the loader valve sounds like a good topic for a separate thread . Have you posted one ?
Don't you think B11lefevre has something very wrong with his 4707 if it lacks power on moderate grades ?
   / Massey 4707 power #11
i am confused about purchasing a mf 4707 tractor. i like the features, but not the headaches that may go with it. any replies to this will be appreciated. thanks tommy
   / Massey 4707 power #12
I agree to a certain extent as I have a 4707 also. If the rpms are down, I agree it is gutless. If I set the preset to say 1100 rpms and start from there everything is good. Mine doesn't have the snap of the throttle like my Kubota 5140 had. What I mean is it reacts a lot like an over the road tractor, you nail the throttle and it climbs slower (compared to a gas job). My Kubota, you hit the throttle and it was quick response. It's taking me a while to get used to that and honestly not really sure I like it.
   / Massey 4707 power #13
I don't think I really have any headaches with mine really. I think it's a good tractor, but it isn't perfect. I haven't owned one yet that was quite honestly. I think as I get more hours on it it will become like a 3rd arm to me. This is my 1st brand switch in quite a while so I expected a learning curve. At this point I think I would buy it again.
   / Massey 4707 power #14
Where exactly was the oil leakin? my 21 4707 with 70 hours just stared to get damp on the front of motor Under the alternator side
   / Massey 4707 power #15
I'm in the 4707 club, but a newbie with only 15 hours on it so far. No significant complaints other than operating the 3pt hitch arms. Every tractor I've ever owned or used has a lever to raise or lower the arms. Easy. Simple. Fairly accurate.
This thing has the plastic thingy that takes the place of the mechanical lever...and then has the "draft control" knob on the right pillar. Apparently you have to use both to raise and lower the arms and for the life of me I don't understand why and certainly haven't mastered it yet, much to my chagrin.
Fine tractor otherwise and so far I'm glad I bought it. This is my third Massey (1540, 1643).
   / Massey 4707 power #16
No, you certainly do not have to use both those controls to utilize your 3pt hitch lift. Check your owner's manual for 3pt lift operation and use of those levers. BUT... I am sure the draft control has a position (all the way back usually) which effectively puts Draft Control out of the picture. Then the Position control lever should operate 100% normally like any other tractor. I don't know if the newer 4700 series uses top link for draft sensing [versus some use lower links] . My MF2660 has/had it and that involved a big spring behind the top link anchor point. If you never ever use Draft control (e.g. for plowing or certain disk operations) then the draft control is just a nuisance. Massey sells a mechanical bypass that disables the Draft control on the 2650/60/70/80 tractors which just anchors the top link to the rear axle/frame and takes the big spring out of the picture. I installed that bypass on mine. More details of you want.
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel 42in...
2023 CATERPILLAR 120 MOTORGRADER (A60429)
2023 CATERPILLAR...
2017 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A59905)
2017 FREIGHTLINER...
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
Sellick S80 (A60462)
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
