Oil & Fuel MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!!
   / MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #21
Here is more pump information from elsewhere on the internet. Another forum, I think, although I've forgotten exactly where I got it. It contains the instructions for actually rebuilding the pump. This goes far beyond what is necessary to just stop the leaks around the throttle or cutoff stems. I hope that is never necessary, as it seems to involve specialized tooling. You may find it interesting.
   / MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #24
I also have a leak, but I am pretty sure it is from a defective gasket. Can someone please send me the instructions for rebuilding the injection pump? I am hoping that I will not have to remove the pump from the tractor to replace the upper gasket, but any help or instructions would be appreciated. Also, any place that sells a gasket kit would be nice too. Please send any information to pottergang1995@aol.com
I tried to download the zipped link provided, but it would not open because it said it was corrupted.
Thanks.
   / MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #26
   / MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #28
I'd like to have that article too, same problem right after getting a new paint job. Thank you for your time.
texstar77@hotmail.com
   / MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #29
JJ. in B.C. said:
Yes it can be repaired without removing the pump but it must be done in the correct sequence, if you would like to drop me an email i will send you an article showing how to fix it.
JJ my email is tjohnny321@gmail.com thank you for the info.
   / MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #30
JJ,
I would like to have that article on MF fuel leak at inj. pump.
Thanks, redgarc
LOT OF AIR GUNS & HAND TOOLS (A58374)
LOT OF AIR GUNS &...
bad boy zero turn 72 (A56859)
bad boy zero turn...
UNUSED FUTURE...
New/Unused CFG Industrial MH12R Mini Excavator (A57453)
New/Unused CFG...
INTERNATIONAL EAGLE ROAD TRACTOR (A52707)
INTERNATIONAL...
New/Unused Mini Crawler Dump (A57453)
New/Unused Mini...
