Oil & Fuel MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!!
   / MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #21
Here is more pump information from elsewhere on the internet. Another forum, I think, although I've forgotten exactly where I got it. It contains the instructions for actually rebuilding the pump. This goes far beyond what is necessary to just stop the leaks around the throttle or cutoff stems. I hope that is never necessary, as it seems to involve specialized tooling. You may find it interesting.
   / MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #24
I also have a leak, but I am pretty sure it is from a defective gasket. Can someone please send me the instructions for rebuilding the injection pump? I am hoping that I will not have to remove the pump from the tractor to replace the upper gasket, but any help or instructions would be appreciated. Also, any place that sells a gasket kit would be nice too. Please send any information to pottergang1995@aol.com
I tried to download the zipped link provided, but it would not open because it said it was corrupted.
Thanks.
   / MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #26
   / MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #28
I'd like to have that article too, same problem right after getting a new paint job. Thank you for your time.
texstar77@hotmail.com
   / MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #29
JJ. in B.C. said:
Yes it can be repaired without removing the pump but it must be done in the correct sequence, if you would like to drop me an email i will send you an article showing how to fix it.
JJ my email is tjohnny321@gmail.com thank you for the info.
   / MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #30
JJ,
I would like to have that article on MF fuel leak at inj. pump.
Thanks, redgarc
Mini Plate (A57149)
Mini Plate (A57149)
CAT 289D3 (A58216)
CAT 289D3 (A58216)
UNUSED FUTURE RB66 66" ROCK BUCKET (A58376)
UNUSED FUTURE RB66...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
Dorsey 4th Axle, Dual Axle, Air Brakes (A59076)
Dorsey 4th Axle...
Lot 163 BALDOR ELECTRIC MOTOR, 25 HP (A59213)
Lot 163 BALDOR...
