MF 230 steering is not working
   / MF 230 steering is not working #1
Tx Brushtrooper
Mahindra, Case, Massey Ferguson
I have a 230 that has a small cyclinder on each side to steer with. I recently changed fluid, filled with hyd 46 fluid. Now no steering at all. Do I need to bleed> If so, where> I cracked a hose at small steer cylinders and it squirts a little fluid here and there, not a stream. What am i doing wrong?
   / MF 230 steering is not working #2
This is a ag mf 230 with the steering pump bolted to front cover
   / MF 230 steering is not working #3
fill it up the. Steer it then fill it some more there is filter in the can
Also if they blow up it is hard to fill while running if it is really dirty could cause slow steering
   / MF 230 steering is not working #4
Oh just saw you used 46 fluid atf works better all I have been putting in them for forty years then you also know when you have steering leak
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
1989 AM General M998 HMMWV 4x4 Humvee Truck (A59230)
1989 AM General...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
PARTS ONLY - Has Title - 2023 Ram 1500 Classic Pickup Truck - Hemi 5.7L - Automatic Transmission (A56438)
PARTS ONLY - Has...
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
