Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 51,575
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
</font><font color="blue" class="small">( Mig is the easiest to learn )</font>
I'd have to say that was 100% -opinion-.
I tried mig first.. couldn't get the hang of the tip to the work.. kept having long wire.. didn't get the feed control right.. ended up welding so far out the shield gas was disipating.. etc, etc..
I grabbed the electrodes to a big ol lincoln 225 and some 1/8 rod and welded up a trailer ramp that out of 3/8 and 1/2 steel that I still use today, to load my JD-B trike tractor.
Everybody is going to have to simply try, then decide what works best for them.
After welding stick for a few years, I went back and learned mig.. I pretty much only use mig for thin metal, and pipe/conduit.. etc. I still use stick for sheet metal. I can do better sheet metal welding with a 1/16 or 5/64 rod using 30a-70a than i can with mig.
As others pointed out, each has it's uses. Real easy to weld dc stick out in the woods using car batteries... might not be easy to get a huge genny and mig out there.. or a gas powered mig.. etc.
As most know.. sometimes we make repairs on the 'fast and cheap' Nothing like high current and good penetration on bad materials with an old buzz box to glue together 2 pieces of rusty 1/2 inch or 3/4 inch metal faster than you can get your gas bottles turned on and grind the spots clean for the mig.
Soundguy
Soundguy
