Mig welder versus stick welder
   / Mig welder versus stick welder #31
</font><font color="blue" class="small">( Mig is the easiest to learn )</font>
I'd have to say that was 100% -opinion-.
I tried mig first.. couldn't get the hang of the tip to the work.. kept having long wire.. didn't get the feed control right.. ended up welding so far out the shield gas was disipating.. etc, etc..
I grabbed the electrodes to a big ol lincoln 225 and some 1/8 rod and welded up a trailer ramp that out of 3/8 and 1/2 steel that I still use today, to load my JD-B trike tractor.
Everybody is going to have to simply try, then decide what works best for them.
After welding stick for a few years, I went back and learned mig.. I pretty much only use mig for thin metal, and pipe/conduit.. etc. I still use stick for sheet metal. I can do better sheet metal welding with a 1/16 or 5/64 rod using 30a-70a than i can with mig.
As others pointed out, each has it's uses. Real easy to weld dc stick out in the woods using car batteries... might not be easy to get a huge genny and mig out there.. or a gas powered mig.. etc.
As most know.. sometimes we make repairs on the 'fast and cheap' Nothing like high current and good penetration on bad materials with an old buzz box to glue together 2 pieces of rusty 1/2 inch or 3/4 inch metal faster than you can get your gas bottles turned on and grind the spots clean for the mig.
Soundguy
   / Mig welder versus stick welder #32
I have never learned to stick weld, however I do my welding with my lincoln electric mig 255. I do not weld for a living, but I do make and fix my own things. This particular welder is not really on the cheap side but it will handle large things as well as the small things. Hope this helps. /forums/images/graemlins/cool.gif
   / Mig welder versus stick welder #33
I do agree soundguy. When I first learned to use mig I experienced the 'long wire' scenario. Then of course, quickly learned to always have my small wirecutters on me. I found that if I wasn't careful I would have a long wire lead and sometimes may weld so close that the wire would affix itself to the nozzle. Then I would have to spend the next few minutes scraping and cleaning. I do use a non splatter spray when I can. It helps.
/forums/images/graemlins/tongue.gif
"the less I know the better off I am"
   / Mig welder versus stick welder #34
Personally, I think that MIG is only easier on thinner stuff and, if you go to real thin, TIG is easier then. I can actually get the best looking beads with a TIG (looks like stacked dimes), but that takes a bit of practice. On 1/8" through about 1/2" stuff, the only advantage I personally see with a MIG is that I have no slag to hammer off and I have no spatter. Over 1/2", I use my dad's submerged arc machine. It dims all the lights in the neighborhood, but it is relatively easy to get a super smooth, deep penetrating, weld.
All take time to learn. Maybe MIG is more forgiving if you have a big crack you are filling, but it still takes some practice time to get proficient enough for a sound weld. Oh yeah, I did first learn on a stick (arc) machine. It really is pretty easy to learn except for vertical and overhead stuff. Learning overhead is the worst; especially with hot slag dropping in your boots and on your shoulders. /forums/images/graemlins/tongue.gif
   / Mig welder versus stick welder #35
Not to sould ignorant, but exactly what is the tig for? I think it is for welding aluminum? Also, I want to tell ya'll to check out the welding helmet at www.accustrike.com
My husband bought me one of these about 5 years ago and I will never use anything else. I will be doing some repair and add-ons to my little tractor this winter so I will post photo's as I go.
Also, I want to add that the hubby also gave me a mig welding course 101 which lasted about 45 minutes several years ago. The rest has been self taught (trial and error makes good) I want to give him alot of credit for having the patience with me.
Now he is mentioning that ever since he showed me this TBN he never has his turn with the computer anymore. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif (i think i am in serious need of TBN annonymous)
   / Mig welder versus stick welder #37
TIG stands for tungsten inert gas, you can weld aluminum, stainless, steel and other metals with it.
   / Mig welder versus stick welder #38
One of the reasons MIG gets a bad rap because everybody thinks its so easy that they don't take the time or effort to set it up correctly. MIG can achieve penetration in thick materials - with the correct size wire, current, and feed rate. How many people bother to change out the wire, rollers, and tip to switch wire sizes when switching base metal thicknesses? You are not going to get very deep into 1/2" steel with 0.025 wire, no matter how high you turn up the voltage! Those who try end up propagating the story that "MIG is for pretty ... ".
Another issue is confusing "pretty" with "strong". Just because the bead is shiny and smooth doesn't mean anything underneath was melted. Beginners can get fooled into thinking they have quickly learned MIG when in fact they have only learned how to lay down a bead, not make a weld. One thing that was told to me that has made a big difference in my weld quality by a more experienced guy was "You have to melt it to weld it". While you are welding, you should literally see the base material actually be melted or even somewhat undercut by the arc and _then_ filled in by metal from the weld puddle. The weld puddle itself isn't good at melting the base metal. The arc needs to hit the base metal, not just the puddle. This is true of all welding techniques. Just melting a bunch of wire on the surface is exactly why detracters call it the "squirt gun".
Outdoors, with any kind of wind, you have to turn up the gas flow rate. A lot. Makes MIG expensive to use outdoors, but still possible. Even indoors, many welding orientations or configurations require higher than normal gas flow. Many don't bother to turn up the gas high enough.
Gasless flux-cored wire is another good option in many circulmstances. Just load up with the gasless wire, close the gas valve, and maybe swap the polarity (as appropriate for the welding situation). The hot flux is much more agressive about cleaning and penetrating poorly-prepped surfaces. Also, the shielding action is much more resistant to wind (exactly like a stick welder). Almost all MIG machines can be used with gasless wire as well. This gives you some of the advantages of DC stick welding and the economy of purchasing only one machine.
You can also buy wire feed setups that are initially setup only for gas-less wire that you can later add the tank and regulator to so as to also have MIG capability.
- Rick
   / Mig welder versus stick welder #39
You can pick up a nice new Lincoln Tombstone or similar for well under $500 and they are all around for way less on Craigs list. You can pick up a nice 120 v mig that will do (on a good day) up to 1/4" for say $550. With the 110v you can pretty much use it everyplace there is any sort of power and it is great for all the tin and thin stuff where you have to use backer plates with the arc. The tombstone or any arc machine running 220v will do just about anything except for thin tin and sheet. It will do everything else though and is easy to switch back and forth to change needs. You can't do that with the mig. Well, yea you can but it is going to cost you (last I looked) say 3500 bucks and you get to plunk all the cash down at once.
My first weapon of choice is always the tombstone. What I weld is often dirty or rusty and can't be fully cleaned which is the bane of migs. 6011 will blast right through the crud and do the deed. As long as you keep it out of the rain that arc welder will last as long as you do while there is a lot more to go wrong with the much more electronic and mechanical mig. I think between the Tombstone, my Hobart 135 and set of Victor Journeyman torches I don't even have a grand invested .
The only thing I would stay away from is the 220 AC only arc welders. DC gives you so many options when the going gets tough and you just don't get that fine arc on AC current which is probably whey they are so cheap all over Craigs list.
   / Mig welder versus stick welder #40
Someone said you'll get better welds with gas compared to flux core wire , I don't exactly agree with that, you get prettier welds yes but better I don't think so! Just my opinion.
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2018 ATLAS V4 - 4 BULB LIGHT PLANT / GENERATOR (A52705)
2018 ATLAS V4 - 4...
2018 JLG G9-43A (A47477)
2018 JLG G9-43A...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
