Milled Asphalt??
/ Milled Asphalt?? #21
I put it on my driveway. Love it. All I had to do was ask when they were milling the road in front of the house, they dumped 4 or 5 loads in the driveway. I spread it with my FEL. Having it rolled would have been even better. Around here it's considered impervious surface. even a gravel lot is considered impervious.
/ Milled Asphalt?? #22
I like it as a base, especially if it can be had for cheap, or even better -free! The quality [size] of the millings effects its utility. The finer milled reforms and bonds much like hot process material. Get it and work it while its fresh, if you can. Some townships require that it be covered with crushed stone, which results in a very serviceable, and still economical wear surface.
/ Milled Asphalt?? #23
Live in NH, have a 3/4 mile long driveway that goes up 800'. The driveway guy used this on his hilltop and recommended it to us because of cost (cheaper) and it doesn't wash out.
My question, I am also looking for a tractor. If I get a tractor are R1s going to tear it up or should I go with R4s. I was thinking R1s because I want to do land clearing and everything I own is sloped.
/ Milled Asphalt?? #24
Our city puts down 4-6" on the hills of our dirt road as it prevents washouts. It was roller compacted and has set up just as nice as a paved road.
Did my drive with that 18 yrs ago and it is still great (about 4-5"), we compacted using the last truckload with bald tires and parallel runs.
Yes you want as many hot sunny days to have it bond.
/ Milled Asphalt?? #25
Slaken
Once the regrind is compacted and has set in the sun for awhile I don't think R1s will tear it up. I spent a good part of a morning trying to tear it up with a ripper so I could lay a new irrigation line across the driveway. Of course a lot of that is my tractor is on the small side. Bottom line, once it sets it is pretty tough.
/ Milled Asphalt?? #27
I run ice chains on my tractor and never have they damaged my re-cycled asphalt surface.
The dual cross ice chains are mounted on turf tires.
/ Milled Asphalt?? #28
If a little diesel is sprayed on it, it melts some of the asphaltic cement. It makes it key together very well. Not great for the environment. Just telling you what I have seen personally.
/ Milled Asphalt?? #29
I would squeege on some asphalt emulsion driveway sealer once I had the surface as I wanted it. Diesel thins the asphalt cement in the grindings and converts it into cold patch that stays live and won't set up. Once cured the driveway sealer will not track around or run off into the environment.
/ Milled Asphalt?? #30
yep.. driveway sealer is what i'd use it..... in that case..
/ Milled Asphalt?? #31
I believe I would do kind of similar, but I would thin the emulsion with water, 50/50, and use hand sprayer, preferably before putting the final lift. I might spray, and hand spread (or 3 pt fertilizer spreader) with rock chips, screenings, sand, or the best fine millings you have, essentially chip sealing it.
That or borrow a tack wagon, and prime/sand properly.
/ Milled Asphalt?? #32
/ Milled Asphalt?? #33
Soundguy said:
there ya go!
ding!ding!ding!
winner! :)
... of coarse why not borrow your buddies 8 ton dump and get a load of asphalt while we are at it. You would be surprised how far 8 tons will go at 1.5" thick (~90 ft x 10 ft). Spread it with loader or box blade, hand lute your tracks, and roll with 4 ton steel wheel.
Its easy to spend someone else's money, time, and sweet.
/ Milled Asphalt?? #34
prime's not too bad though. can always lay the millings and wait till there is a road project in your area, and then pay the co to zip over and shoot your road. take a few minutes at most. backup.. spray and go. and then you can sand.
/ Milled Asphalt?? #35
Leeboy makes or made? a nice ~250 gallon tack wagon, perfect for small paving jobs like gas stations, patches, and turn lanes, I was surprised how nice it shot.
Soundguy, dumb question, but what does prime or tack cost per gallon, I know we typically pay $0.25 per square yard in place, and use mostly Special MS or RS-2.
/ Milled Asphalt?? #36
we use special ms as well.. and yeah.. .25 per is what we are getting. seems universal around here.
I'd have to pull an invoice at work tomorrow to tell you what we are paying per gallon of the mix. typically we will buy only 2500g at a time unless we are really moving and have a few jobs lined up. remind me tomorrow if i forget to get back to you on the special ms.
/ Milled Asphalt?? #37
Once the diesel dries it shouldn't track. Truthfully if you spray it on a good hot day and roll the heck out of it the millings will stay put for along time.
I am not sure how strong the ae sealer would be in this application. I have sealed millings for people in the fall time but never followed up with them.
/ Milled Asphalt?? #38
diesel doesn't dry.
/ Milled Asphalt?? #40
Ah, you guys make me cry! "Spray some diesel on it"! In the great state of Mass. that would get you 5 to 10yrs in the can! Actually, when there is a big time accident and a significant quantity of diesel or no. 2 oil is spilled on the road, They bring in a milling machine and mill the surface and repave over it.
The milled asphalt of course goes right back to an asphalt plant where guess what- state of Mass code now allows up to 30% RAP in new mix!!!:banghead:
Salt Dog by Buyers Slide in Spreader Box 10' (A62679)
Salt Dog by Buyers...
1999 Volvo Sleeper (A62613)
1999 Volvo Sleeper...
2016 Hyundai Box Trailer (A62613)
2016 Hyundai Box...
Kubota Industrial Turbo Diesel Engine - Tag Missing - Pump Takeout - Approx. 80-85 HP Class (A63689)
Kubota Industrial...
Pole / Log Dolly (A62613)
Pole / Log Dolly...
2019 FREIGHTLINER M2 4X2 S/A 26FT NON CDL BOX TRUCK (A59914)
2019 FREIGHTLINER...
