Millermatic 350P (first welds)
   / Millermatic 350P (first welds) #51
Well, thanks to this old thread I am 4k poorer but can now pulse mig weld. Need to get it set up after delivery today
   / Millermatic 350P (first welds) #52
Yeah these forums have a tendency to make a guy spend money.:eek:
Looking forward to seeing your pictures:cool:. I've never run a 350P. I hear they're a fantastic machine.
I haven't played with pulse to much on steel. Little bit on aluminum tho.
   / Millermatic 350P (first welds) #53
350P should be ok now. At one point not long ago they had a 100% failure rate. Great machine otherwise. The Lincoln V-Pro, 350MP and Thermal Arc Twin Pulse SP series are a better mousetrap although the SP is 2X the 350P price. All are modern technology Inverters but the Miller is not actually digital. It's analog with digital interface where the others mentioned have true digital micro processors. Do they all Pulse Weld? You bet they do.
   / Millermatic 350P (first welds) #54
What is pulse welding ? Is that when I bump the trigger to keep from burning a hole on a poor joint ?
   / Millermatic 350P (first welds) #56
I finally got mine going over the summer - and after doing just a little bit of welding with it, I have to say it was worth the money if it makes me a better welder. I have to get better at setting it correctly, but when I did it produced a really nice weld.
   / Millermatic 350P (first welds) #57
Jim are you using the pulse setting when welding? Is it hard to set up?
Terry
   / Millermatic 350P (first welds) #58
Wow, what a welder. Effortless thus far
   / Millermatic 350P (first welds) #59
Pulse and short circuit work so well I am not sure when to switch (steel)
   / Millermatic 350P (first welds) #60
When I was using a 350p on a frequent basis with a former company, I never saw any reason to short-circuit except maybe some odd out-of-position work.
INOP/NON-RUNNING 2000 Ford F-450 Pickup Truck, VIN # 1FDXF46S9YED80883 (A44391)
INOP/NON-RUNNING...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A46877)
John Deere 5090E...
2018 Ford F-550 4x4 Flatbed Hi-Rail Truck, VIN # 1FD0W5HT0JEC21009 (A44391)
2018 Ford F-550...
10ft Fork Extensions (A44571)
10ft Fork...
Ryobi Compound Miter Saw (A44391)
Ryobi Compound...
2003 Ford F-250 4x4 Pickup Truck, VIN # 1FTNW21P93ED18234 (A44391)
2003 Ford F-250...
