jim_wilson
- Joined
- Jun 13, 2004
- Messages
- 1,794
- Location
- Northeast MA
- Tractor
- Kubota B3200 w/ BH77 & 12", 18" & 24" buckets, Kubota B50 SSQA w/ 54" & 60" buckets, LandPride FDR1660, Artillian Fork frame, Extreme 3pt rake, Concrete Mixer, MyTractorTools grapple adapter
Well its Been flawless but I don't use it exclusively. I tend to use it on the larger jobs more than the smaller ones. The pulse spray is great but very hot to use. When you want to do top quality welds this is the unit to use but on heavier metals.
I use my MM 252 70% of the time. Fast set up for general mig use and I just love the 252. I run .035 on the 252 and .045 on the 350P. 90/10 gas on the 350P and a special blend on the 252. I think its 25/75 but they call it blue shield something or another.
The 350 P with the 30 amp spool gun is great for aluminum and its the unit I use for all my mig aluminum work.
Both units have been 100% reliable. As a matter of fact I've never had any issues with any of my Miller gear
( knock on wood)
I have a Dynasty 200DX that I bough new with over 2400 hours on it with zero problems so I'm a happy camper when it comes to Miller.
I'm somewhat undecided on whether to just get a 252 - or spring for the 350. I'd like to be able to do aluminum, and I'm assuming that the 350 will do everything that the 252 can do - and then some.
Is there a reason why you choose the 252 over the 350 70% of the time? I'm wondering why not just use the 350 for everything? Is it just a convenience thing more than anything - so you don't have to swap the config around on a single welder to do different jobs?
