mini hay balers
   / mini hay balers #21
In case anyone is still looking at these old post...I bought a Star mini-round baler in spring of 07. I bale 7-10 acres right now with potential to go to 25 acres. The Star will bale dry as well as wet. I did both using a Star mini-bale wrapper. I would never go back to a square baler. The main reason I chose small round bales is because I don't have or can't afford all the "big" equipment to go bigger. I can cut, rake, bale, and wrap all with a 33HP tractor. A secondary reason is because I bale wet and a 1200lb balage bale starts heating pretty bad before my 4-6 cows finish it. With mini-bales, I can feed one a day without problems. If anyone wants to see the equipment, go to tractorconnection.com. They had the best prices I could find on the west coast.
   / mini hay balers #22
Z you are thinking it all wrong ;) talk to the farmers / show people at the fares in your area. many will be in need of alfalfa you may be able to get a good deal skipping the middle man. and you get to write off all expenses of the fare as business ;)
Aerway Tillage Tool (A59814)
Aerway Tillage...
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
UNUSED FUTURE HYD AUGER (A52706)
UNUSED FUTURE HYD...
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
1660 (A59213)
1660 (A59213)
CATERPILLAR CB24B DOUBLE DRUM ROLLER (A52707)
CATERPILLAR CB24B...
