Missing 777
   / Missing 777 #241
A pair and a spare is a good, safe rule. .
been a long time since i heard that.. but ditto.
good mantra when you are not on the ground...
   / Missing 777 #242
Even with all the redundancy built into our aircraft we still routinely practice landing with failed primary flight controls.
We do this in the simulator during our recurrent training.
Not only is it possible to fly an airplane without most of its flight controls, it has been done. Back in the late 80s Capt. Al Haines landed a United DC-10 in Sioux City Iowa after a loss of all hydraulics. That aircraft has 3 independant hydraulic systems but no mechanical backup, an explosion of the number 2 engine caused fragments to penetrate a junction where all three systems passed in close proximity causing all fluid to be lost.
Unfortunatly some people died in that accident but the heroics of the flight crew saved most of the passengers.
   / Missing 777 #243
That was some incredible flying skill. Too bad so many people died. But despite the tragedy, it could have been a lot worse.
   / Missing 777 #245
Hey, if a person believes in conspiracies, then all they have to do is to say/allege something then it becomes a fact that supports their grandiose view of how somebody is out to get them. Logic and facts, provided by mossroad and others, take a flight of fancy and are best ignored or attacked.
Else they have to admit there is no conspiracy, and that is not permitted when they are in denial.
   / Missing 777 #246
An old dude taught me that saying a long time ago. To this day, I try to build redundancy into my mission-critical systems by having two complete systems and a good set of spare parts. However, in this economy, bean counters tend to question every purchase. I can't blame them. I just have to make an argument that if we are down for X hours, we will lose X dollars. If they see fit to justify losing X dollars while we are down, then so be it. At least they knew that going in and I have a clear mind. ;)
   / Missing 777 #247
I am finding that when I am wondering what is going on with this disaster that I am ignoring all news statons and coming directly here to TBN to see what the experts have to say. Thanks guys for keeping me informed. A real great bunch of people all connected by having tractors.
   / Missing 777 #248
spotted from satellite....unclear what the two objects are...aircraft en route.
It's dawn there so we should know within the next 12 hours what the objects are (assuming they can find them).
   / Missing 777 #250
   / Missing 777 #251
Except that IF you are having a fire and redirecting to another airport, why would you be saying "Good Night" at the handoff rather than "Mayday, Mayday, we are on fire and need to redirect to airport X" so that airport X can clear the way for you to get in and get the rescue equipment warmed up just in case?
Aaron Z
That is the $64,000 question that has plagued all of these theories.
   / Missing 777 #252
Aaron Z
Thanks for not pruning my post.
Using my powers of deduction.....I am left to decide that perhaps the fire burned through the communication wires after the pilot signed off, later he is discovering the fire or subsequent smoke.
How else would it make sense?
   / Missing 777 #253
Edit: The plane made the course change AFTER the signoff at 1:19AM and AFTER the Transponder was turned off at 1:21AM, but the change was programmed into the Flight Management System BEFORE 1:07AM and 12+ minutes BEFORE the signoff. Timeline from CBS (see ~0:28 for where they talk about the programmed course change): http://www.cbsnews.com/news/from-ta...al-a-timeline-of-malaysia-airlines-flight-370/
Aaron Z
   / Missing 777 #254
Where can I find this Timeline? First I've heard of one.
   / Missing 777 #255
I think that any course deviation from the one filed would have been questioned by ATC and there would have been no "good night" conversation or handover under that scenario. Any time an airliner on a filed flight plan makes a course or altitude change they will talk to ATC first for clearance, even (and especially) if it is an emergency. When operating in "controlled airspace" you can't just do what you like.
Identifying Classes of Airspace:
  • Class A: all airspace between 18000' and 60000'. Not identified on charts. (mnemonic: Above everything)
  • Class B: airspace around large regional airports. Identified on charts by thick blue lines. (mnemonic: Big airport)
  • Class C: airspace around large city airports. Identified on charts by thick magenta lines. (mnemonic: City airport)
  • Class D: airspace around small airports. Identified on charts by blue dashed lines. (mnemonic: Dashed line)
  • Class G: uncontrolled airspace. From the ground up to the next overlying airspace (usually E). (mnemonic: near the Ground )
  • Class E: controlled airspace. Floor is 14,500' MSL, and extends up to the next overlying airspace (A, B, C or D). (mnemonic: Everywhere else) Exceptions:
    • Class E floor is 1500' AGL if surface is above 14,500' MSL
    • Class E floor is 1200' AGL (or more) if inside shaded blue line
    • Class E floor is 700' AGL if inside shaded magenta line
    • Broken blue lines differentiate Class E floors when floor is above 700' AGL
As you will see by attached chart example, there are LOTS of V airways crossing that chart and unless you want to be talking to ATC the only way you can legally cross one is below 1200ft AGL.
Sorry if I was unclear. As I understand the timeline, the plane turned off course (towards this other airport) about 10 minutes BEFORE the "Good Night" radio transmission, thus evidencing that the radios were fully functional for at least 10 minutes after the plane made a major turn off course so as to (per the aforementioned blogger) head to an alternate airport for an emergency landing and well after the first beacon stopped transmitting.
Aaron Z
   / Missing 777 #256
Well, the plane DID change course fairly dramatically with a new waypoint programmed into the Flight Management system.
That waypoint was added before the last automatic data transmission at 1:07AM.
At 1:19AM, someone (Copilot?) sent the "All right, Good Night" transmission.
At ~1:21AM, the transponder was shut off
At that point, it was out of the Malaysian ATC control and far enough out to not show up on ATC radar without its transponder.
It then made a left turn and was tracked by Malaysian Military radar just after 2AM, with it disappearing from there around 2:15AM
The engine transponder stopped reporting engine status at ~8:15AM
A couple of stories:
The search online for missing Malaysia Airlines FLIGHT MH370 | Mail Online
Malaysia Airlines Flight 370: Possible debris from missing plane spotted in Indian Ocean - CBS News
http://www.nytimes.com/2014/03/18/w...-cellphone-calls-from-missing-passengers.html
Aaron Z
   / Missing 777 #257
There is no mechanical connection between the pilot and the control surfaces. No cables. No pulleys. No rods. Nada. Nothing but sensors, wire and computers to convey the movements of the pilots controls, convert them into data, transmit them to the other parts of the plane, then convert them back into mechanical force at the control surfaces through hydraulic and electric systems.
Had to do some more research to clarify what I thought I had heard. I guess it might be "sort of" flyable with a computer failure.
http://www.davi.ws/avionics/TheAvionicsHandbook_Cap_11.pdf
11.5.2 Mechanical Control
Spoiler panel 4 and 11 and the alternate stabilizer pitch trim system are controlled mechanically rather
than electrically.
question about 777 flight controls [Archive] - PPRuNe Forums
Part of post 1:
I was wondering if the 777 fbw controls allow for manual reversion.
Part of post 2:
The above modes still require electric power. When it is not available, the mechanical backup you refer to is used to control the plane.
It consists of cables from the flight deck to selected spoilers, and the stabilizer. As far as I know, there are no cables to the rudders.
Part of post 8:
The only control surfaces mechanically connected to the flight deck on a 777 are a pair of flight spoilers and the horizotal stab trim system.
Bruce
   / Missing 777 #260
Aaron Z
This time line has a significant variation from the one you are referring to. According to CBS, the significant change in course happened 2 minutes after the sign off. The transponder stop transmitting after the pilot said "all right good night".
From takeoff to final satellite signal - a timeline of Malaysia Airlines Flight 370 - CBS News
2022 KOMATSU D71PXI-24 CRAWLER DOZER (A60429)
2022 KOMATSU...
2018 KOMATSU D65EX-18 CRAWLER DOZER (A60429)
2018 KOMATSU...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
2018 NEW HOLLAND C232 SKID STEER (A60429)
2018 NEW HOLLAND...
2020 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A60429)
2020 PRINOTH...
