For those of you that want to see what a waterfall display looks like here are some photos. Please excuse the Moire(interference) pattern to the screen, as apparently the scan rate of the monitor and the scan rate of the camera seem to set up an interference pattern on the photo. I will assure it does not look that way in real life. I suppose I should have taken a screen snap and saved it as a .jpg file.. oh well you get the idea.
This is the actual radio on 14.070Mhz. its display is showing the amplitude of the signals in its RF passband . in this case plus and minus 50 khz from the center frequency of 14.070 but the IF passband is set to 3.0 khz. So the audio sent to the computer will be restricted from about 100hz to 3.0 Khz. making the center frequency about 1500 hz. In the sonar rig, their center frequency is likely to be set to the 37.5khz and they will look for a small frequency band either side of that.
here you can see signals (PSK31 signals mostly and noise) through out the passband up to about 3.0khz. The cursor is set to about 2.260khz and is not currently decoding any signal at that location. The text in the receive window box is from previous decodes.
Here the cursor is set for about 1.675khz and is currently decoding the text you see in the window of a station in Germany calling CQ, and wishing to make contact. Notice that his signal is fairly weak, and notice the extremely strong signal on about 875hz.
Now you know more than you ever wanted to know about waterfall displays, And while these pix of radio signals and their recovered audio are different than sonar displays the concepts are the same. And the goal was to show you what signals look like on a water fall, and to help explain why I think no sonar operator would ever have any difficulty distinguishing the difference between a biologic (animal) and a man made pinger with a precise frequency and time domain signal.
And for those of you who know me well, yes I am a gun toting right wing redneck of the first order, but there is a technical side to me as well.
