Model L and Model C Repower Parts
   / Model L and Model C Repower Parts #1
gravelymay
Cleveland Tenn
Repower to 1 inch crank Engine parts :thumbsup:
This gear can be used for repowering the L Model C8 & C10.
It is made for 1 inch dia crank shafts 3.3/4 long
also can be used on 3.00 long crank shafts
For repower over head engines.
Here are some better pictures.
Thanks Bruce g
423 716 4611
   / Model L and Model C Repower Parts #4
That's the best one I've seen, also.
Here is a LI Frankenstein That I put a 13 Hp Honda on .
Runs out good :thumbsup:
But the wheels are to close to the deck.
It don't have a remote control lever for the PTO.
The forward & reverse lever is backward to me.
I plan to fix all three.
Thanks Bruce g
423 716 4611
   / Model L and Model C Repower Parts #7
Bruce, this is very interesting. The cost of Gravely parts is simply obscene these days. My only concern is that we'll have the same problem with the modern engines as with the Kohlers- the PTO speed is too fast for the implements like the sickle bar and even the rotatry plow. Any ideas on a way to reduce the PTO speed?
   / Model L and Model C Repower Parts #8
HI! With Gravely L model we have two PTO speeds In low range engine speed 2400 rpm give about 800 rpm PTO and for 2800 rpm engine we have 1000 rpm speed. In high range for 2000 rpm engine PTO rpm is 1000 rpm and for 2800 engine rpm PTO is about 1400 rpm. I use a Gravely L model with reduction gear wheels My 10 hp diesel can turn 3600rpm I never use this speed. I run it at about 2400 rpm because this is (as near all engine) the maximum torque engine speed. More engine speed take more fuel and give less torque. We cannot use modern engine at less 2000rpm. 2400 is the minimum for me. I use my Gravely with rotary plow at 2400rpm with no problem. I dont know the sickle bar but I think Me be you must use the low range. Good luck! Oldmech
   / Model L and Model C Repower Parts #9
Oldmech, that's the problem, even with the low range the Kohler PTO speeds are way too fast for the sickle bar and I personally think also for th erotary plow.
   / Model L and Model C Repower Parts #10
Hi! I think for sickle bar mower.You are right. I am building a special sickle bar mower for my Grillo. With pulleys and belt we can change ratio. I seen many tractor PTO sickle farm mower. The drive pulley from 540 rpm is more large as 10 in. to 8 for the driven. So after belt slipping about 600rpm. Gravely PTO minimum 800rpm is over or too high. I plan about 600 rpm for my special Sickle bar mower. Good Luck! Oldmech
UNUSED AGT SSPOC HYD LOG GRABBER (A52706)
UNUSED AGT SSPOC...
2017 Nissan Versa SV Sedan (A55853)
2017 Nissan Versa...
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
2015 Ford F-550 Stellar 7621 7,500LB 3 Ton Crane Service Truck (A56858)
2015 Ford F-550...
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
2015 Chrysler 200 Sedan (A56859)
2015 Chrysler 200...
