moldboard plow questions
   / moldboard plow questions #31
Nice job Erik. My Dad was a hard critic on anyone's plowing. He was a perfectionist when it came to fully turned soil!
Frank
   / moldboard plow questions #32
Centering of plow to c/l of tractor will balance the pull on the tractor equaly to the driving wheels . On a 2 bottom plow at 12-14" furrows on a 35 Fergie size tractor the top link usually not run straight that is why wheel track settings front -rear inside measure need to be the same. [I prefere the front wheel 1-2" wider ] When both lower arms converge at the same angle [relative to c/l of tractor] you are not far off. Adjustments to disc culters draft bar position [l-r] rotation of bar alignment of last furrow landslide [bent] has a direct effect on plow alinement to tractor. Always consider the landslide to a rudder on a boat 1 degree off will turn boat [l-r] same with a plow; disc setting is critical on last furrow along with ware and side movement in spindle . cammax
   / moldboard plow questions #33
The JD book on plowing, suggests the tractor settings from center of the drawbar to the inside of your right rear tire be 23 1/2" for 12 inch plows, 25 for 14" and 27 inches for 16". Of course, some minor lateral adjustment can be made on the plow cross drawbar. Ken Sweet
2015 Volvo VNL 64T (A55315)
2015 Volvo VNL 64T...
BETTER BUILT FUEL CELL (A58214)
BETTER BUILT FUEL...
1608 (A57192)
1608 (A57192)
2009 Kubota RTV1140 (A57148)
2009 Kubota...
1999 International 9200 Day Cab Truck, VIN # 2HSFMAHR0XC036739 (A57453)
1999 International...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
