More hydraulics on my 4100 Hydro
   / More hydraulics on my 4100 Hydro #1
GaryM
Warrenton MO
JD4100 Hydro
Anyone have any ideas on what it might cost to add hydraulic outlets on the rear of my 4100?
I'd like to be able to add/use a top and tilt on the 3PH. I'm thinking maybe outlets at the rear with QD and maybe a push button on the existing joystick so the control for my loader could divert power to the rear outlets.
I'm prepared to be shocked.:eek:
I'd want it all installed and operational, not just a parts kit.
   / More hydraulics on my 4100 Hydro #2
Since you are prepared to be shocked and want it installed for you, that leaves you with basically only one option. You are at the mercy of your local dealer. I believe you can get parts pricing from the JD website. Then figure in your dealers hourly labor charge to install.
Or you can simply give the dealer's service department a call, but only while sitting down.:D
I probably should have made a deal when I bought the unit a few years back, but at the time I was fighting for a tractor and my wife wanted me to get a riding mower. So adding a bunch of $$$ at that time wasn't an option. What do they say, "pay me now or pay me later!"
I'm not certain exactly what parts would be required, so will be dependant on the dealer for that.
I've never felt a need for top and tilt before, but have recently been working on our subdivision roads and it's "get off the tractor and adjust the tilt of the box blade, blade a little, then get off again and make more adjustments" I'm now a believer!
   / More hydraulics on my 4100 Hydro #4
Gary, I added 2 remotes to the rear of my 4110, essentially the same machine as your 4100.
My total price was about $500 for parts, labor was free. I guess if you paid a dealer it would be in the $750 to $1000 range, if he even want to take on the project.
You can view my project here:
http://www.tractorbynet.com//forums/showthread.php?t=69599
Please feel free to ask me any more questions...
Oh by the way, there is on cheaper alternative, but you must answer this: Do you have a FEL and is it installed when your are maintaining the roads?
   / More hydraulics on my 4100 Hydro #5
Yep Gary,M, KennyD's thread is very good. when i was going to install some additional Hyraul's i really reviewed it hard. Very informative.
OK, I read the thread and now am a little smarter than I was. :D
I went to see the dealer on Saturday and we did some research in the books. It looks as though a Power beyond kit along with a ROPS mounted valve is the way to go. Maybe the dealer read the same thread? There is a four outlet QD kit shown in the book, but it's no longer available. And it doesn't have any valves anyway. Just a bracket with four QDs.
He's supposed to come up with a price complete with install for the following:
PB kit installed and a dual valve with QD mounted at the ROPS
Above with the addition of a hyd cylinder to replace the tilt turnbuckle
All above with a hyd cylinder to repalce the upper 3pt link.
Depending on how the prices are, I'll go as far as I can at the time. I'd at least like to get the PB kit and valve installed.
I currently have a Pat's Hitch installed and it makes it relativly easy to hook up implements. A hyd differental on one draft are would make it even easier! ;)
   / More hydraulics on my 4100 Hydro #7
Yes, That's why I asked if you use your loader...That kit is just four hoses that run from the front QD's to the rear. Completly usless if you use your loader!
   / More hydraulics on my 4100 Hydro #8
Good and keep us informed.
   / More hydraulics on my 4100 Hydro #9
Good Luck that is.
Dealer called Friday and left a message. I called this morning to confirm the details.
Price is $1050 :(
That's the power beyond kit, a double selector valve, a mount for the bracket in the vicinity of the ROPS, and four QD's mounted on the valve.
Installation time/labor is included.
It does not include cylinders and hoses to replace the top link and adjustable side link.
I don't know what those will cost, but they are something I could obtain and install myself. :D
If my finance manager, wife, says OK I think I'll have the parts ordered and installed. Then I can add the cylinders and hoses as I can.
Price is higher than I'd like, but lower than I'd feared.
   / More hydraulics on my 4100 Hydro #11
Gary, Why don't you want to do it yourself?
Several reasons I guess:
Plenty of other things to do instead.
No help readily available.
Might run into a problem I can't solve.
No facilities to readily create the required bracket.
Easier to write a check!
I guess the last one is the most important.:)
I will purchase and have hoses made for the cylinders rather than get those from the dealer. And I will mount the cylinders when it's time for that too. Any good sources and recommendations for those parts?
   / More hydraulics on my 4100 Hydro #13
Try Discount Hydraulic Hose. Prompt, fast service, knowledgeable people to talk to on the phone, great inventory, online catalogs, and most importantly good pricing. Recommended by many here on TBN.
   / More hydraulics on my 4100 Hydro #14
Fair enough answer Gary, Got to like a man you is honest!
Mad covered you on the hoses...
KennyD,
My dealer doesn't have a 4100 to measure the space available between the ROPS and seat to mount the valve. So I'm going to measure tonight. They did obtain the Power Beyond kit and that makes me happy because they were not sure it was still available.
The links you provided for your Danfoss valve and the Eaton -Cessna valves don't work anymore. Do you have the model or any additional information on either valve? They have a valve, but are not sure it will fit in the space available.
   / More hydraulics on my 4100 Hydro #16
Gary,
The valve I used is not available anymore it seams, but here is the one I would use, Its a compact valve that should fit nicely on your machine:
Surplus Center Item Detail
Let me know If you need more help...
KennyD,
I saw that one and wondered if it was the Eaton-Cessna mentioned in your post.
I took some photos and will email them to my dealer tomorrow. He said he has a valve but wasn't sure if it would fit. There's approx 6" between the seat and the ROPS, so I think it won't be a problem.
Why did you make new handles? Disn't the valve you used come with levers?
Planning to order cylinders from CCM tomorrow. At least the top link cylinder.
Thanks.
   / More hydraulics on my 4100 Hydro #18
Great Gary,
Sounds like your well on the way! Just make sure your dealer doesn't cram some huge 20 GPM, 25 lbs. monster valve on there. I would go look at it first held on the tractor before you OK it.
Why did you make new handles? Didn't the valve you used come with levers?
The Danfoss valve I got did not come with handles, and a local supplier was less than helpful getting me some. That's why I suggested the Cessna compact as better option.
Please take some pictures for us:D
   / More hydraulics on my 4100 Hydro #19
That Eaton-Cessna valve is a great choice for any low gpm compact. I have personally recommended and helped install them. You will be surprised at how small it really is and it will fit almost anywhere without being big, ugly and obtrusive. Just make sure you get it with the power beyond sleeve.
   / More hydraulics on my 4100 Hydro #20
What is the flow on this model of tractor? Is it less than 5 GPM?
Adams 5 T Fertilizer Spreader (A61307)
Adams 5 T...
2013 NISSAN NV3500 CARGO VAN (A59905)
2013 NISSAN NV3500...
John Deere 7410 (A53317)
John Deere 7410...
2020 KENWORTH T680 SLEEPER (A59904)
2020 KENWORTH T680...
2012 John Deere 6170R (A57148)
2012 John Deere...
2000 Bobcat 763 (A60462)
2000 Bobcat 763...
