More Shed Questions...
   / More Shed Questions... #1
Dougryan
Webster, NY
Cub Cadet 3206
I know, that shed guy again... humor me for a few more questions.
So I was thinking about a 14 x 20 shed and stared to design and price out lumber. This will be a stick build 2x4 walls with rafters made from 2x6. I plan to use collar ties on every rafter and a ceiling joist on every other. They will be spaced at 24' OC.
Question 1 - When looking at the boards for the ceiling joists (14') I found that my local lumber supply typically has 8', 10', 12', and 16' boards. No 14'. So I would need to buy 16 footers and cut off two feet.
Hmmmm... would it be better to just plan a 16x20 shed? 40 more square feet of space. Small extra cost of a couple of wall studs...
So 14x20 or 16x20? I'm leaning toward 16x20.
Question 2 - Floor material... wooden platform on skids or concrete?
Thanks,
Doug
   / More Shed Questions... #3
16x20.. Concrete if you can, skids with PT flooring if you can't..
   / More Shed Questions... #4
I like to plan a building around the materials that I will finish it in. Metal roof panels are 3 feet wide. Plywood or OSB is 4x8. Hardie lap siding is 12 feet long. For me, the ideal size for a shed would be 12x24, but if you want to go wider, then 16 is a pretty good width.
Are you going to have an overhang? Will your soffits be vented and what will you use? Hardi and Smart make soffits that are pre drilled for venting that are very nice. I think that they are 18 inches, but I would double check for sure. So you would want to add that to the outside measurement of your walls if you are wanting to span your ceiling joists with one continuous board. My lumber yard sells 2x6's up to 28 feet long and I can get them in every length from 8 to 28 in two foot increments.
Lowes sells 2x6x14 boards here.
https://www.lowes.com/pd/Top-Choice...Common-1-5-in-x-5-5-in-x-14-ft-Actual/4082910
   / More Shed Questions... #5
16x20 and floor based on other considerations. Some jurisdictions consider portable buildings to be personal property thereby not subject to property tax. Some jurisdictions tax personal as well as real property but at different rates. Also ask your agent what it cost to insure each. No way I would try and build it protable if zero turn,atv or other wheeled equipment is to be stored. If you go with concrete,have you priced material and labor for pole barn construction with metal siding?
   / More Shed Questions... #6
I'm not sure what roof slope you are working with, but I would go as wide as possible using 12 foot long lumber for the rafters, spaced as required for roof loads. Keep in mind that your ties don't have to be at the top of the wall. You can raise them and use shorter lumber.
   / More Shed Questions... #7
So OP is planning a flat roof with no eaves!?!? Otherwise 16’ rafters with the original footprint sounds like the right length.
Letting the size of lumber dictate the building size and or your needs is bass acwords.
   / More Shed Questions... #8
I once hired a guy to build a shed to store my garden hose. When I returned,I had a 1'x1'x50' building.:confused3:
   / More Shed Questions... #9
16'x20' on concrete PT for plate nice looking metal roof plus good ventilation.
   / More Shed Questions... #10
???? 16 foot rafters would result in a building about 28 feet wide. In planning buildings, I have usually taken the approximate size and fine tuned it to match standard lumber sizes.
1994 HEIL BULK TANK TRAILER (A59575)
1994 HEIL BULK...
3 Row Twin Row Renaldo Planter (A53317)
3 Row Twin Row...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
CAT D5G LGP DOZER (A58214)
CAT D5G LGP DOZER...
John Deere 5105M (A53317)
John Deere 5105M...
Polaris Ranger (A56859)
Polaris Ranger...
