Moving from 1/2 ton truck to HD truck
   / Moving from 1/2 ton truck to HD truck #91
My 2011 2500 tows good the few times i used it towing.Bought a tuner for it but never turned it up.
   / Moving from 1/2 ton truck to HD truck #92
Have a very sweet Ram 1500 Hemi truck I got new (leased) last year.
Been thinking about moving up to a HD pickup to make towing my big enclosed trailer easier. Diesel HD trucks are insanely high in price. Even with 150k miles on them, you’re looking at $50k around here. So I opened my search up to gasoline HD trucks as well. I found a 2021 Chevy Silverado 2500HD with the new 6.6 gas engine. Sweet truck, extremely well cared for. Problem is, the 6.6 gas is a 400 HP engine. The axle is a 3.73. The trans is the old 6L90 that’s been around since 2006 and the ratios are really tall. So, I threw that combo into a spreadsheet along side the same info (power, trans ratios, axle ratio) from my Ram 1500. Looks like my Ram has significantly more pulling power in every gear, despite the 3.21 axle ratio. If my truck had the 3.92s it would be a bloodbath. But yeah, power/gearing advantage from 0 to 70 miles per hour. AND my truck is 1,500 lbs. lighter so that increases performance even more over the HD. I get that a HD truck is heavier and therefore in theory should handle/steer better with a trailer but I have a hard time justifying a move up to HD to get worse acceleration, fuel economy, and maneuverability. Sigh…
The Ford gas HD trucks can be had with 430 HP, 10 speed trans, and 4.30 gears which is a stellar combo but they are like finding a needle in a haystack. I can’t find one in my price range anywhere in this entire region.
The Ram HD gas trucks are nice but they seem to be abused on construction sites or work sites and by the time I find them on the used market they’re pretty rough.
"When going to HD trucks, go straight to 1 ton"? That’s what I was thinking too. But I looked up the tow chart from GM’s own website and it is surprising. The 2500 gas can tow more than the 3500 gas (only a couple hundred lbs., likely the difference in weight between the 11.5 and 12.0" axles). The payload gain on the 3500 is less than 500 lbs. If you go diesel then there’s a couple thousand lb. advantage for the 3500, but that’s not really a huge deal either. Surprising though that on the gas trucks the difference between “3/4 ton” and “1 ton” is almost zero on paper.
Are you buying a tow vehicle, or a daily driver? You have to choose. That's why I own a 2000 F350 PSD AND a 2007 Camry. The Camry takes me back and forth to work, gets groceries, picks the kids up from practice, ect. The truck hauls the camper, hauls the tractor, hauls firewood, and goes hunting. The truck used to be my daily driver, but when fuel hit $4/gal, the Camry paid for itself in 2 years (I drive around 20K miles/yr).
As far as fuel mileage goes for trucks, my 1994 F150 (straight 6) got 21 mpg on the interstate. My '93 F250 diesel was in the high 17s. My 2000 F350 is in the low 16s, but with a 7 pos chip it was getting close to 18. I've heard rumors of 3/4 ton trucks getting more than 18, but I've never actually seen one do it.
   / Moving from 1/2 ton truck to HD truck #93
I have a 2020 3500 6.7. This is my third HD Ram Diesel, 2003 2500 and 2014 3500 previously. They are rock solid. I did a lot of research before my purchases. The biggest mistake I see people make is getting a 2500 instead of 3500.
Now if you're not going to really tow or haul a lot, ok. But your plans may change in a few years and it's better to have the capacity and not use it then not have it and need it.
As a previous poster stated look at the payloads. Most 2500s only have about 2000#. That includes hitch weight, driver, passengers, fuel and everything else in your bed.
My 3500 has a 4000# payload. Night and day. Spend the extra money and time and find a decent 3500 especially if you're going to have it for a while.
   / Moving from 1/2 ton truck to HD truck #94
I have a 2013 RAM 1500 4x4 with the 3.6L gas engine, and 8 speed transmission (plus 4 low). It really knows how to downshift to get power.
I work it pretty hard towing (flatbed utility trailer), and am impressed with the performance. Eventually I'll add airbags or helper springs.
I've hit as high as 25 MPG driving empty. Usually around 20 MPG if the trailer is empty, and 13 MPG to 16 MPG with the trailer loaded.
I'll probably try a 5.7L pickup, but I'm not convinced the larger engine is actually needed.
Absolutely you are correct. I looked into this a lot. What I found on the Ford trucks is that F-250 and F-350 are the same truck minus an additional leaf or two in the rear spring pack. Everything else about the trucks are the same. Ford sprinkles the GVWR and trailer towing numbers with magic fairy dust for marketing purposes. In fact, you can option the F-250 to be mechanically identical to the F-350, so the only difference is what they print on the door jamb sticker. It's literally marketing rather than mechanical difference. The Ram trucks are a little different because the rear suspension setup actually changes between 2500 and 3500. But even then the rest of the truck is the same aside from that.
So, since I'm using this truck for personal use only and not commercial, I decided to buy whatever I could find that met my criteria (lowest miles possible, under $45k, crew cab, 4x4, good pulling power) and this F-250 popped up so I jumped on the chance. Previous owner put air bags on it to supplement the leaf springs, which I doubt I will ever need, but since they are there I will never wish I had bought a 1-ton.
   / Moving from 1/2 ton truck to HD truck #96
I was in the same position but needing a bit more load handling....why buy a pickup?
I bought an International 9200 single axle semi with 150k miles on it with the big Cummins and a Eaton 10spd for $18k.
Pulls better then any new HD truck your gonna buy and at 1/4 of the cost.
Yep, I bought a 359 Pete in very nice condition for $20K, then made it a single axle.
Ironically, the mileage really wasn't all that different from my current Ram 3500, although the 3406B and 18-speed could pull a whole lot more.
At times I definitely wish I hadn't sold that Pete, but these days I never exceed 39,000 CVWR so the 3500 C&C does the job.
   / Moving from 1/2 ton truck to HD truck #97
If you have a gas truck that will get up to 16 MPG with a loaded trailer you better hold on to it because you aren't likely to get that lucky twice.
   / Moving from 1/2 ton truck to HD truck #98
Indeed! My '14 1500 with the same engine and trans got similar hwy mileage, but just an empty 16-foot flatbed wiggling around back there sucked it down to about 10 mpg.
Yes, I tried it once, just to prove the obvious to myself; don't tow with a 1/2-ton.
   / Moving from 1/2 ton truck to HD truck #99
I had a 2005 ram1500 and found it did not have the payload capacity I needed, looking at the frame it was big enough, but the spring were not, I solved this by buying pep boys coil spring helper package and mounting them under the leaf spring mounts, I had increase the hole size to bolt on the springs but that was easy, and I also added a set or Monroe air jackets in place of the originals. I could now haul anything I wanted to without problem so the solution may be you just need to upgrade the springs
   / Moving from 1/2 ton truck to HD truck #100
Anyone who does this is a real piece of %^&.
Diesel exhaust particulate matter is a known and proven carcinogen. Intentionally defeating your emissions control just to blast it into someone's face is evil. Coal rollers should go straight to jail.
Sorry, rant over, let's not derail Mule's thread. I'm sure his scorpion 6.7L is running nice and clean, as it was meticulously engineered to do. But all your initial observations about driving a 3/4 ton are part of why I went the other way for my next truck, lol.
Yeah I don't do that. No one rides bikes here.
UNUSED INDUSTRIAS AMERICA SK72 72" HYD BRUSH CUTTE (A51247)
UNUSED INDUSTRIAS...
2010 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A53426)
2010 PETERBILT 387...
FELLOWS PAPER SHREDDER (A53843)
FELLOWS PAPER...
2013 Ford Edge SEL SUV (A51694)
2013 Ford Edge SEL...
2014 CAT  299D TRACKED SKID STEER (A53843)
2014 CAT 299D...
1996 International Water Truck with a Caterpillar Engine (A53472)
1996 International...
