My Diesel Storage and Transfer Set-up
   / My Diesel Storage and Transfer Set-up #31
What Diesel treatment do you use from Wall Mart for this?
I already us Power serivice in the white bottle.
Thanks.
== L B ==
bialecki said:
After about 9 months of owning the 30 gallon caddy I don't have condensation nor other water in the tank. It does not have a drain in the bottom. I just add Diesel treatment that you can get at Walmart and it absorbs whatever water may be in the fuel, so no problem to date.
If you have any questions with the Northern diesel pump PM me and I'll help if I can.
I forgot the name of the diesel treatment that I use. It is indeed the treatment sold in the white plastic container. LBrown59 I am sure you will enjoy the neat new pump.
   / My Diesel Storage and Transfer Set-up #34
How about this idea, just get a 55 gallon drum and a siphon starter. When (actually before) the tractor needs fuel, lift the drum with the bucket loader, put the hose in the tank (ok, it needs a long hose), and start the siphon. When it's full, put the barrel back.
I am sure you can rig an air line to pressurize the 55 gallon barrel so that you can transfer the fuel by this pressure differential. However a small air compressor would be needed.
   / My Diesel Storage and Transfer Set-up #36
I'm thinking of welding D rings to the sides to enable lifting it off of transport trailer. Do you think this is feasible. My gas caddy has just arrived and not yet been used.
Not being an expert welder, but everything I read is not to weld a fuel tank that had prevoiusly been filled. Since you indicated it is new and never been used, this is the time to do it. However I would continuously purge the inside of the tank with argon or another inert gas to minimize crystallization on the inside of the tank while welding the hooks/ rings on the outside.
   / My Diesel Storage and Transfer Set-up #38
bialecki said:
I purchased this 30 gallon diesel caddy from Northerntool.com and added their 12 volt 5 gallon/ minute pump. With a little plumbing and a couple of three-quarter inch ball valves I can now transfer diesel from my 5 gallon containers into the caddy for filling or directly into the tractor. This setup eliminates the need to lift the 5 gallon 35 pound containers chest high and try to hold the container while filling the caddy or the Kubota. The wheels on the caddy makes it portable enough to move about within my garage or driveway for easy transfer to the tractor. I did add a 14 foot fuel line with a manual nozzle. The nozzle is convenient when filling my B7800 due to the cross member/ brace that Kubota added for the FEL that crosses right over the fuel cap of the tractor. Attached are a few photos showing the caddy and a close-up of the plumbing. I used the yellow Tygon line to transfer the fuel from the 5 gallon containers to the caddy and the black line with the nozzle from the caddy to the Kubota.
This is exactly what I have been looking for and have gone as far as to order the equipment from Northern to build. Can you tell me what lengths all of the 3/4" nipples are? Thanks. P.S. Brand new subscriber so if I didn't do this right - please help.
A quick look at the photo reminds me that I used 3/4" X Close nipples and one 3/4 X 1" nipple connected to the 3/4" union. Use as many 90 degree Street Elbows as possible to eliminate another nipple (Street Elbows have one end threaded). All materials I picked up at Lowe's or Home Depot. I like the looks of Galvanized better than black iron, but either will do.
   / My Diesel Storage and Transfer Set-up #40
Thank you Sir.
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54607)
2020 INTERNATIONAL...
1996 Ingersoll-Rand VR642C (A47477)
1996...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A55218)
2022 Gravely...
2015 Ford F550 Altec Bucket Truck (A52377)
2015 Ford F550...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
2016 CATERPILLAR 730C2 OFF ROAD DUMP (A51246)
2016 CATERPILLAR...
