My Garage/Shop Heater Install
   / My Garage/Shop Heater Install #71
Awesome. This time tomorrow you will be tankful the job is done!
   / My Garage/Shop Heater Install #72
Good one Terry, made me proud :D
Mark, when I looked at those I noticed there were about half a dozen "re-badges" with different names; hopefully all the copy cats picked one of the better ones to steal :laughing:
The other one that got some good reviews (although not as many)
https://www.amazon.com/dp/B07CWQJD6...jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
That one seems to have a tiny bit wider range (+- 2.99 psi instead of 2) but either will be more range than you need for under 1/2 PSI
If your weather's been like mine, you can put your stuff outside to do the rock in about 6 months :rolleyes:
The good news - your new heater won't help your stuff rust by adding several gallons of water to your inside air :thumbsup: ... Steve
Steve, I did a test blow (with my mouth) and the meter seems to be working!
Yeah figuring July/August? Or next year for mud work. :ashamed:
I am sure hoping the sealed combustion style will lower my humidity. I would love to get significantly below the outside especially during the winter! I did a couple vise restorations a while back and the unpainted slides have an orange color that is not appealing. Gonna have to disassemble and put a clear coat of something on I guess.
I HATE RUST.
   / My Garage/Shop Heater Install #74
Amen... and don't forget mold
   / My Garage/Shop Heater Install #75
If you have a spare 120 outlet, might wanna look at cold weather dehumidifiers (they work at 10-20 degrees colder) - with our wood heat humidity doesn't seem much of a problem. In the (un-heated mostly) shop I keep 100 watt bulbs under anything that's rustable, keeps the iron above dewpoint.
My guitars/basses/drums/piano all like 45-50%, in the house the wood stove keeps it below 53 most of the time. In the studio, a milkhouse heater on an external thermostat and a small fan keeps things comfy.
I may end up putting small ones (dehumidifier, not guitars) in each container once I get power to 'em. You'd be surprised how quick their tank fills up, when I've used 'em before I ended up plumbing to a drain instead of tryin' to remember to empty... Steve
50% max is my target.
   / My Garage/Shop Heater Install #77
Oh, if you just wanna KNOW what's going on I've had REALLY good luck with previous versions of these
https://www.amazon.com/AcuRite-0108...igital+humidity+temperature,garden,239&sr=8-8
I have 'em in 3 different areas I care about, their accuracy claim isn't BS - when I got 'em I borrowed a SERIOUS Hygrometer from work - put all 3 of the small ones and the REAL one in the same small area, let 'em settle in - they ALL read within 1/2% of each other. I had one of those "do everything" satellite clock thingys, the hygrometer part is lucky to get within 15%... Steve
   / My Garage/Shop Heater Install #78
"50% max is my target. "
Good plan - if that isn't practical (like in my unheated, uninsulated shop) the light bulbs will keep metal surfaces above dewpoint, it's actually worked better than I'd hoped... Steve
I have a previous 'black n white' version in my shop now. The remote outdoor transmitter stopped awhile back but I do get indoor humidity reading. Seems always at least 66% these days.
I went LED lighting and and not getting the inefficient heating I used to. :laughing:
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 (A55787)
2016 New Holland...
20X30 ALL STEEL CARPORT (A55745)
20X30 ALL STEEL...
2021 JOHN DEERE 648LB GRAPPLE SKIDDER (A52705)
2021 JOHN DEERE...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
2017 Ram 4500 Bucket Truck (A55302)
2017 Ram 4500...
