My new old 2N
   / My new old 2N
as you noticed they have very limited timing adjustment.
introdue ANY wear, and you get a situation where you can onoy set it 'clos'
I know guys that can't get points open to .015 due to wear...
Crazy thought, when you press the dizzy shaft out does the point lobe come off too? Or is it part of the shaft?
Like I said someone had recently replaced point and condensor and shaft bushings. If the point lobe is deprecate and they did not mark it can the point lobe be removed and forwarded about 16 degrees? That would put it where it needs to be.
The fellow I bought this from is not mechanically inclined in any way hard to say what he did or did not do.
   / My new old 2N #42
liner will fix that type of leak if you prep correctly.
there is a finger sized screen atop the tap.. a round disc screen int he tap.. and the screen in the elbow
   / My new old 2N #43
should go out front with no replaceable lobe.. if it has thrust play look at the back of her.
i don't have a front dizzy in my hand mind you. mine has been installed on my 2n since 04.. which was also the last time i had to set points and timing on her as well.
12ft Heavy Duty Aluminum Ramps (A53473)
12ft Heavy Duty...
TEST BID LOT (A50775)
2018 DODGE RAM 3500 LARAMIE SERVICE TRUCK (A51406)
2018 DODGE RAM...
2021 JOHN DEERE HX14 (A53084)
2021 JOHN DEERE...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
