Need advice on NH 1715 PTO Issue
   / Need advice on NH 1715 PTO Issue #1
kgiovann
This is a repost from original placed on gen'l forum
1993 1715 bare bones. 600 hours maintained well. Very low torque when PTO is turning deck mower, for example. At normal power, RPM's remain normal, but PTO rotation and tractor speed slow considerably, especially on inclines. The deck mower has always slowed a bit in thick grass, but this is different - the PTO rotation and tractor speed almost stop.
I know better than to attempt this repair myself, but I'd like some advice on some simple checks before I have the dealer come out and pick it up. Also, if the clutch on this is bad, how can I keep the dealer honest on repair costs? What's reasonable? Thanks.
   / Need advice on NH 1715 PTO Issue #2
Do you know if you have live PTO.? Tractor data reports only transmission driven PTO. If you have transmission driven PTO or single clutch, I think there is a good chance that clutch is slipping when you need torque greater than what you need to move the tractor. Do you have on the right side of tractor a rubber inspection hole? advise if you do, and I can suggest a simple non- invasive check to see if clutch is slipping with torque applied to PTO shaft.
JC,
Not sure if it's live, but. . . There is no inspection hole/window anywhere on ther right. An large oval rubber bootie on the left, but it's located in the middle of a hole pattern so I suspect thats for hydraulics which I don't have (loader).
When transmission is in nuetral, pto still spins - does that indicate live or single? Cluth pedal connects to linkage above pedal and pushes an actuator when fully depressed. I can post a picture if needed. Thanks.
   / Need advice on NH 1715 PTO Issue #4
In transmission driven (single clutch) PTO, the pto will continue to turn in neutral if PTO handle is engaged. same happens with live clutch. One way to make sure is to do the following:
with tractor running, clutch all the way, engage pto lever, put the tractor in gear, let go of clutch and start moving . you should be moving forward and pto turning. While you are moving clutch halfway, that should kill the power to the wheel, tractor should come to stop while pto remains turning. in that point while stopped if you push the clutch pedal all the way down then PTO is stopped. if you can duplicate it then you have live Double clutch ) PTo.
post a picture on the oval boot that you are talking about. on 1700 oval boot is on the right side and you can inspect and adjust clutch in the clutch housing.
JC,
Based on what you describe, this is a single clutch system. PTO and transmission both stop simultaneously.
I took the boot off the access hole on the left side I described, and it may provide access to adjust the clutch. Picture provided which also shows the pedal with linkage and actuator. Thanks.
   / Need advice on NH 1715 PTO Issue #6
Kgiovann,
Yes that is the access for clutch adjustment only if you have double clutch. clutch adjustment on single disk is done outside and basically is adjustment of release bearing surface to pressure plate fingers. no adjustment as far as pressure plate can be made. In other word if clutch disk wears out beyond it's spec then pressure plate/flywheel and disk in between will not be able to maintain adequate torque.
With single clutch, engine off, PTO engaged, gear in neutral, clutch pressed in by help of a block of wood and then you can simply turn the clutch disk by help of a some sort of stick or a screwdriver. clutch disk is free to spin since pressure plate is not pushing against the disk.
Now one way to check if clutch disk is slipping or not is to maintain all the conditions above minus engaging the clutch ( clutch pedal all the way up) and tractor in some gear rather than neutral. In that fix you can have an assistant to try to turn rear pto shaft by using a pipe wrench. if clutch plate is gone and you do not have much grabbing force than you can see with the aid of a flash light the slippage of the your clutch disk. in this fix pto should not be able to turn unless clutch is slipping. don't put too much torque on the pto shaft, and keep watching the action thru the peep hole while your assistant tuning the wrench.
All I'm saying is that you might have enough torque to move the tractor but not enough to operate the pto using a heavy, torque intensive implement. You might have issue with your pto ORC (over running clutch) as well and that's a whole different scenario.
Replacing a clutch disk would be an easier endeavor. Test it out and report. I would not go overboard on turning the pto shaft with mechanical advantage. don't want to bust any gears just want to check clutch slippage.
JC,
in pic below yo see the pressure plate on the left side and two sides of the clutch disk and flywheel on the right.
   / Need advice on NH 1715 PTO Issue #7
JC-jetro,
I am having a similar problem with my Ford 1715 but with a 5' rotary cutter. I know I have a single live clutch. The cutter and PTO stop turning and thus cutting randomly. no change in engine RPM or load that I can associate with the stop of the PTO. Engine runs fine and never bogs down. The odd part is I have a 5' finish mower that runs fine and never stops like the rotary cutter does. I am thinking that the clutch is out of adjutment and cant take the torque of the 5' Rotary cutter.
So my two questions for you are could you guide me on how to do a clutch adjustment? I was thinking I should try this before sending it off to the repair shop to see if it would help. Second do you think moving down to a 4' rotary mower would make more sense ($500) than replacing PTO clutch ($1500-$2000)?
thanks fo your advice!
Fred
   / Need advice on NH 1715 PTO Issue #8
JC-jetro,
Fred
Fred,
You can't have live pto and single clutch at the same time. With single clutch you have a transmission driven pto. having live pto and you have a dual stage clutch( 2 clutch disks, two pressure plates both sandwiched in one assembly). Thru the peep hole (hand hole) on th side of you clutch housing you can for sure tell what clutch you have. have you ever seen the picture or actual dual clutch?
I know you said the engine does not bog down but do you lose forward motion about the same time you lose pto power?
I think finish mower requires less amount of torque than does the rotary cutter. Do you have any issue with your brush hog's gear box? do you have enough oil in the gear box. is anything in drive mechanism of your brush hog that is binding? do you have slip clutch for your rotary cutter or do you have shear pin?
You do not have PTO clutch (hydraulic independent) pto. If you have live pto then you have to change you main clutch pack that includes both pto and transmission both in one assembly.
I do not have dual clutch so I have not done adjusting it myself. if you need, I can post procedure off of IT book if you don't already have. I have read the procedure before and find it not too difficult. The fact you are saying no issue with finish mower leads me to believe that there is a good chance your problem may not be pto.
Check the stuff I suggested and report back.
JC,
   / Need advice on NH 1715 PTO Issue #9
Hi JC,
Thanks for your reply. Sorry I do have a single clutch on this tractor.
I do not loose forward motion when the mower quits. It is quite frustrating as several times I have driven quite a ways before I realized the mower was not spinning. It just slowly winds down until the blades are not spinning. In order to get it going again I have to clutch in, stop and cycle to PTO lever a couple of times.
I checked the mower gear box and there is oil in it about 1/2-2/3 of the way up the vertical gear. This mower has a slip clutch I think (2 round plates bolted together at the point where the PTO shaft attaches to the mower?) It all turns very freely when I move the blades or the PTO shaft. That is what makes me think it is the PTO because the PTO shaft from the tractor to the mower stops turning but not rapidly it just seems to loose implusion...so the PTO shaft and blades slowly wind down as I am driving along at the same speed.
Also I did the test you recommended on another post and removed the mower and PTO shaft and I placed the tractor in Neutral and engaged the PTO and truned the tractor engine off. I was easily able to turn the PTO shaft clockwise. When I tried to turn it Counterclockwise abotu 70% of the time it would not turn but 30% of the time I could easily turn the shaft counterclockwise. So does that tell you anything?
Thanks!!
Fred
JC,[/QUOTE]
   / Need advice on NH 1715 PTO Issue #10
Hi JC,
Thanks!!
Fred
Fred,
The fact that tractor does not slow down when you lose pto suggests your main clutch is probably okay,
When you tested your pto, did you have clutch in or out?
No matter what with internal one way clutch pto shaft will turn CCW just fine. With clutch out it will rotate easily and with the clutch in pto rotates if you have clutch slippage.
You do have slip clutch on your cutter. if It is loose you may not transfer power to cutter head but Main pto shaft before clutch should maintain the same speed.
important question: when you realize the pto slowed down/quit woorkingm would you notice the pto engagement shaft (stick) is jumped out of engaged position? what do you do to get it work again? There is a dtent ball and spring that keeps the pto in engaged position, if that slips cause the disengagement of the pto.
If you have pto ORC (over running clutch) issue , then I'd think it'll be working or not, nothing in between.
I'm hoping that your pto just jumps out... a simple bungee cord to keep the pto engagement shaft may be simple short term solution.
JC,
JC - this relates to the original post I made on this thread where tractor and PTO speed simultaneaously drop while engine RPM's remain high when torque is needed.
First, I confirmed with the selling dealer that this unit has a single clutch system.
With power off, clutch in, PTO engaged and stick in neutral, I can peek in and see separation between the disks and can turn with a screw driver. This you probably expect.
When I repeat above with clutch out and stick in gear, I can turn the PTO cw with my fingers without the clutch plate moving. . . I didn't expect this. I was unable to turn ccw, even when using moderate force with a pipe wrench.
   / Need advice on NH 1715 PTO Issue #12
1With power off, clutch in, PTO engaged and stick in neutral, I can peek in and see separation between the disks and can turn with a screw driver. This you probably expect.
2When I repeat above with clutch out and stick in gear, I can turn the PTO cw with my fingers without the clutch plate moving. . . I didn't expect this. I was unable to turn ccw, even when using moderate force with a pipe wrench.
Kgiovan,
In scenario 1 it only shows that clutch disk can be free and rotation of that can turn the final pto shaft, meaning all the shafts and gears are meshing okay.
In Scenario 2 it shows that your ORC works fine and clutch is not slipping. Both are good and desired outcomes. The fact that you can turn in one direction is that the ratchet is holding in one way and releasing in other way and that's proof of correct ORC clutch. I don't suggest this at all, but applying more torque should push the tractor forward.
I can not see that you have PTO issues. when you look thru the hand hole do you see oil in the bottom of the clutch housing?. I'm just reaching here , but it might be clutch is on it's way out and when the torque is high depending on implement used in addition to the torque required to move the tractor is enough to start clutch slippage. Let's see if anyone can shed some more light.
JC,
Interesting.
   / Need advice on NH 1715 PTO Issue #13
JC,
Well I have had great sucess with the bungee cord idea! It has been mowing great for the short stint of dry weather i had to mow today. I think your right that the PTO was just slipping out of gear b/c of a loose handle. It is not 100% as the PTO stops spinning sometime when abrupt change of direction of when decreasing RPM, but SO much less frequent than before! When it does stop now all i have to do is push in clutch and then let it out to get PTO spinning again.
Thank you so much for your help and advice!! you saved me a ton of $$ and time!
Thank you!
Fred
   / Need advice on NH 1715 PTO Issue #14
JC,
Thank you!
Fred
Hey Fred,
Glad it worked out:). You might consider making a bit stiffer bungee mechanism using some wire a bit stiffer than bailing wire and make yourself a loop that you can put over the handle and attached to something in the differential area. A bit of imagination and few minutes and you'll be good to go. I think that'll sustain you for quite a long time and aesthetic:rolleyes: is in the eye of the beholder. On my gear shifter I have same type of detent mechanism that keep the stick shift from jumping out. I have not figured out on the pto detent if it is more internal or access to it can be archived from outside. I'm pretty inquisitive person and if I have time I'll take a looksy and will report. I wondered if any of our more learned colleagues here been there , done that.:D
JC,
By the way, It'll be better next time if you start a brand new thread, I had to go back ad forth between you and the original poster to sort out my answer.:)
Detent mechanism for the stick shift, four in all.
JC, since no one had anything to add, I've been limping along with it until now where it takes 60-90 seconds to even get the tractor moving (PTO not engaged). I literally have to wait that long in gear before I start moving. Once it heats up (thermal expansion?) it's better but still no power. It sure feels like the clutch is slipping.
Can I try a simple clutch adjustment (single clutch) before resorting to writing a big check, or ordering a service manual and tackling a clutch replacment? Thanks.
   / Need advice on NH 1715 PTO Issue #16
Sorry kgiovannn for your continued issue. Again, with a single clutch you have transmission driven pto. PTO ORC(over running clutch) is a one way ratchet only and gives some impression of transmission type clutch. There are other flavor of PTO clutch that works off of a set of clutch disks that is hydraulically pushed together to cause the grabbing force to couple a driven shaft with a driving shaft. You do not have that. Your pto ORC either makes or not make and there is nothing in between. if your ORC is bad you still should be able to move with pto engaged or not engage. if anything is slipping, is you main transmission clutch. The clutch adjustment for single clutch is literally just a "free clutch pedal play". The only time that would hurt you if the pedal by adjustment always pushes some pressure on the pressure plate. it is the same as " riding the clutch" as some people have a bad habit of leaving their left foot on the clutch pedal. doing so for a long time causes premature wear of the disk material hence less grabbing force. I understand that there is a rubber hand hole on 1715 as well that you might be able to look at disk itself. The disk thickness on either side of middle steel disk should be around 3/16". it'll be obvious if the clutch plate is consumed.
Forger the pto for a minute, can you put the tracor in gear when cold and be able to move without hesitation. Report and we may be get a bit closer.
If the release bearing is not touching the fingers on pressure plate then there is no way adjusting the " clutch free play" is going to add grabbing force to worn out clutch disk. If I'm losing you somewhere let me know and I'll explain.
JC,
Ps. One of the guys ending up changing his pto ORC on 1715. He said 1715s had an issue with their orc. bad part of it that rear diffy needs to be split.
You can make a gage to measure from a piece of card board. My clutch plate thickness is 95% of original.
JC- I think we're there in terms of identifying the problem. Clutch disc thickness (both sides of middle steel plate) is less the 1/4". No way to get calipers in there but remaining thickness is nowhere near 3/16. I may try an adjustment to buy time, but it's worn out.
I also read the other post you suggested. Since my PTO and back wheels BOTH lose power at the same time, I don't think it's the PTO override. Also, when the engines cold and the PTO level is disengaged, the tractor still takes a long time to get moving. It's a strange sensation sitting there in gear with the clutch out not moving.
The transmission clutch adjustment is straight forward - Mechanical on the outside.
I have an operators manual, but I'll pick up a service manual. Is that the book I need? I also see shop and parts manuals available on line. Service manuals are available for < $200, so that sounds like a good investment.
Thanks for the sage advice. I'll update!
JC - correction. Thickness on plates is less than 1/8 inch, not 1/4 as I stated earlier. I doubt even an adjustment will help but I'll give it a try.
   / Need advice on NH 1715 PTO Issue #20
Hey KG,
The fact that tractor is sluggish to start with or without PTO engaged is almost proof positive that your clutch is slipping and is worn out. The only remedy for it disk replacement. Transmission clutch is friction based, and so called PTO ORC is a one way ratchet only, grabs one way and slip the other way. One of the guys has done an overhaul plus a clutch replacement. With permission :eek: I'll post it below.
The first picture is the clutch for 1700. It might be a bit different in shape with 1715 but function is identical. You see the big flywheel, and a pressure plate with 3 brown color fingers. The clutch disk is sandwiched between the two.
In this picture you see transmission input shaft and a mechanism to push on pressure plate fingers. it includes a hub (cast) and a bearing that sits on top. You push the clutch pedal and bearing touches and pushes the fingers in causing the disk to be separated from the flywheel. All the external adjustment you do is only going to cause surface of bearing to get closer or further from the fingers and that's all. The only way adjustment can help you is if the bearing was constantly pushing the fingers at all times (way out of adjustment). in a fix like that you'll loose grabbing force (friction).
This is picture of my 1700 where you see how close the release bearing is to pressure plate fingers but not touching it.
The picture of clutch housing from top with steering column removed.
are you able with tractor off and clutch pedal out get a flat head screwdriver and move the clutch disk up or down? That is also a sign of major slippage.
I have IT manual that I bought for less than $20, it is okay for the price but not as good as service manual.. it is anemically adequate. I'll post the adjustment below for now till you get a manual. I still think replacement of clutch disk is easier job that replacing pto internal ORC.
Good luck
JC,
2005 John Deere 7320 (A60462)
2005 John Deere...
2018 Ram 1500 4x4 Crew Cab Pickup Truck (A59230)
2018 Ram 1500 4x4...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
PALLET OF (3) CABINETS (A60432)
PALLET OF (3)...
2017 Toro Workman HDX-D Diesel Utility Cart (A59228)
2017 Toro Workman...
Year: 2012 Make: Ford Model: F-350 Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 Door C... (A59230)
Year: 2012 Make...
