Need Clutch Plate
/ Need Clutch Plate #1
oldgeezer
Western Arkansas
2007 Kubota GL3240
I have 2 old 2 wheel walk behind tractors. I use both of them. One is an old Simplicity that I bought in pieces that were in a bushel basket about 40 years ago. I gave an old man $15.00 for it & didn't even know if the parts were all there & if they were I didn't know where they went. I cobbled around with it, figured out the gears, shafts & such & finally put it together. It was all there but the rachet dogs for the wheels. Someone had drilled & keyed the wheel so that both wheels pulled at the same time & you could not turn a corner with it at all. I made some dogs with a grinder, put them in so it would rachet, put an old Tacumseh engine off of a mini-bike on it, rigged up a middle buster behind it & have been digging potatoes with it ever since. Still has original tractor tires on it. At a dead idle, it will dig potatoes like you wouldn't believe.
Other is an old David Bradley minus the hood & saw attachment. It was sitting outside & motor was locked up but I broke it loose & got it to running like a Singer Sewing Machine. The guy gave it to me & later I had plows given to me from other sources though I did have to buy a disc at an auction for $10.00.
I have the turning plow, cultivator, disk harrow, & Georgia type plows for it & they all fit & work. I have used it many times to make terraces in garden & ditches for drainage. It had no tires but wheels were there so I put 15" car tires on it & added snow chains on them. It will bury any plow, spin about a round & away it goes. Problem is, the old clutch is badly worn & now slips when in a strain.
DOES ANYONE KNOW WHERE I CAN GET A CLUTCH DISC FOR IT?
Thanks a lot for reading.
/ Need Clutch Plate #2
For the Simplicity or the David Bradly?
/ Need Clutch Plate
For David Bradley. It has a real clutch plate. Simplicity uses a belt tightener clutch.
/ Need Clutch Plate #4
Any pics of the clutch in question? Brake and Clutch in Dallas could usually rebuild/reline anything with linings. Don't know if they have a place near you or not. Might talk to some of the large trucking company's near you and see where they get theirs done.
Here's a link that might be useful
Brake Linings Supplier's Directory from MacRAE'S BLUE BOOK
DEUTZ MARATHON...
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
2018 International WorkStar 7500 Aquatech B-15 Combination Sewer Jetter Vacuum Truck (A59230)
2018 International...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
Deere 310L (A53317)
Deere 310L (A53317)
2018 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2018 Chevrolet...
