Need guidance in selecting Mower vs Yard Tractor
   / Need guidance in selecting Mower vs Yard Tractor #112
Yeah I dont see anything that shows they are standard.
Right now the Massey GC1715 is my front runner, it has the most power of all the machines. I got a quote of 15,450 for the tractor,fel and belly mower from the local dealer
I think you can do better than this price.. Check Tractorhouse.com if you are willing to drive a little you may be able to pick one up for less.
TractorHouse.com | 215 MASSEY-FERGUSON GC175 For Sale
   / Need guidance in selecting Mower vs Yard Tractor #113
You have received a ton of good feedback. I did not even have a computer when I was researching my tractor. You are very lucky and smart to come on here and ask questions from tractor owners across this great land. I was looking on tractor house and saw two 2016 Massey Ferguson 1526's for sale ($16,900 & $ 15,900). Both are located in Ohio. Both are new. For that amount of money you could step up the size of your tractor from a SCUT for close to the same price. Just an idea. You could also look at other brands in that size also for pricing. You would have a heavier tractor, little more loader power, and higher lift capacity at the rear. Plus you would have more ground clearance. I know when I bought my New Holland TC40 I really did not know a whole lot about tractors but I researched the living daylights on everything tractor related in that size. I ended up buying in another state 6 hours away. I got a 20 ft trailer, filled tires, and a loader bucket. I saved $ 7,000.00 driving the 6 hour distance. The same tractor in my state was a whole lot more for the same set-up. The only downside was the dealer was a long way away. Luckily for me I never had any warranty issues. Only thing I would have done differently now would have been to go with the TC45 instead. The tractor was new left over from the previous year. I did the same thing with my Gravely zero-turn. Bought it new leftover from the previous year.
When I bought my tractor I thought it was HUGE. Once I started using it on my land it got a lot smaller.
   / Need guidance in selecting Mower vs Yard Tractor #114
I agree, this is good advice.. don't think you have to buy in the state. Any dealer will work on it as long as it is under warranty and/or you bring money.
   / Need guidance in selecting Mower vs Yard Tractor #115
lots of thing to think about, I had a 2305 jd worked just fine for me had it 7 years, then in november stopped at john deere and looked at a 2032R really liked it and and looked for a good used and found it at a jd dealer had around 100 hours , got a new cozy cab and a lot of attachments for it I really like it dont think it will be replaced by me,hope it last me the rest of my life.
The 15450 price was the out the door price for the tractor,loader and belly mower. Its actually 14100 with the financing options I'm considering so if I pit nothing down it''s around 195/month
   / Need guidance in selecting Mower vs Yard Tractor #117
Have you physically operated all these choices? How it "feels" to you is important, You should add tractor/loader/mower out the door prices and monthly finance costs to your spreadsheet. They are all kind of equivalent. Here are some differentiators that may or may not make a difference to you:
  • Ease of removing loader (Hydraulic quicl detach couplings)
  • SSQA bucket (skid steer quick attach)
  • Telescoping 3 point ends (easier to hook up attachments)
  • Pin type 3 point stabilizers vs turnbuckles
  • Cruise Control (nice but not necessary)
  • 2 vs 3 Hydro ranges
  • Size / Height of tires (TRACTION)
It is kind of nice to have one additional hydraulic remote if it doesn't break the budget. Once you a close to signing the papers, ask them if they will throw in a rear blade.
Probably a dumb question, but what would be the difference in a belly mower vs buying a pto mower? I found a couple finish mowers nearby for less than $1000. Massey dealer wants $2300 for the belly mower
   / Need guidance in selecting Mower vs Yard Tractor #119
With the rear PTO mower you wouldn't be able to have anything on the back. Like if you wanted to mow and have a vacuum or bagger on back. Or mow and tow a wagon. Or have to take the mower off every time you want to put an implement on the back. Also, consider maneuverability. In my case, I wanted to mow my entire lawn, including close to the house, with the tractor. I was concerned with a rear mower swinging wide and being an issue. I can pop the loader off in 5 minutes tops and drop a rear implement in seconds after flipping 2 levers on the quick hitch and lowering the arms. That shortens the tractor by a lot for close quarters mowing. I even have a bungee on the chute to pull that up and out of the way when needed.
   / Need guidance in selecting Mower vs Yard Tractor #120
Mid PTO spins at 2000rpm, 3pt spin at 540rpm and for cutting a yard I would rather have a mid mount mower.
It gets really expensive if you have to add the mid PTO and add the MMM, I have been quoited 6k to add that to a 1533
1999 CLEMENT END DUMP (A58214)
1999 CLEMENT END...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2017 John Deere HPX Gator Utility Cart (A56857)
2017 John Deere...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2018 Ford F-350 (A55973)
2018 Ford F-350...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A56435)
2017 Yale GLC050VX...
