2ndhalf
Probably a dumb question, but what would be the difference in a belly mower vs buying a pto mower? I found a couple finish mowers nearby for less than $1000. Massey dealer wants $2300 for the belly mower
Manuverability and probably cut quality unless the rear mount mowers are good quality finish mowers. I mowed 5 acres with a landpride 72" finish mower behind a Kubota B7800 for a summer. It did ok but we had a small push mower that we went and trimmed around things before mowing. It was not that bad and my wife often used it. It was certainly not a ZTR but it was better than a garden tractor also.
I have a tractor with no belly mower and just a loader and I like not having a belly mower to worry about ground clearance.
This isn't a bad option and then you could buy a ZTR if necessary later down the road so you keep the hours off the tractor. Your grass would get mowed and look decent. But if you are picky about how your yard looks I think a belly mower will do a little better job.
Whatever you do I highly recommend trying to finance a FEL with the tractor. They are pricey to put on after and a tractor without a loader is very close to just a heavy lawn mower.
