Need Help Heater Does Not Work
   / Need Help Heater Does Not Work #31
Sandy,
Did you check where my return line is routed in my previous post/pic. Maybe you could route it the same?
Hope it helps
Thanks for the comments, what would we do without TBN. /forums/images/graemlins/grin.gif
The needle NEVER reached the red line on the temp gauge, when I saw it climbing above the normal range, I stopped and took the plastic off. So I think I am OK. I only put the plastic on the radiator in take because other folks here on TBN have done so, see link below. Knowing that I will have good heat even at -10 F is great to know. /forums/images/graemlins/wink.gif
Regarding the Sims cab heater I did not get the Sims heater. I picked up a Curtis Cab heater from e-bay and installed it on the left side of the cab. In the summer I take the cab off , but leave the heater and bottom half of the Sims cab on the tractor year round.
I put plastic on the in-take radiator inside of the cab so you do not get the cold being sucked into the cab. I did take the panel out from under the battery to give the engine a place to get air.
web page
   / Need Help Heater Does Not Work #33
</font><font color="blue" class="small">( what would we do without TBN. /forums/images/graemlins/grin.gif)</font>
We'd probably all get a lot more work done, that's what. /forums/images/graemlins/laugh.gif
But we all wouldn't be so darn smart either. /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif
WARM wishes to all, John
   / Need Help Heater Does Not Work #34
Sad, but I agree with the "redrill and retap, below" school of thought ...in fact, the whole point of the thermostat is to insure a supply of hot water. Used to be that we installed "winter thermostats" in our cars to make sure the heaters worked adequately ...and, if necessary, reverted to "summer thermostat" if overheating was a problem when the weather turned hot.
2019 Ford F-350XL (A53314)
2019 Ford F-350XL...
UNUSED Under Mount Stainless Steel Sink & Faucet (A53117)
UNUSED Under Mount...
New/Unused Pallet Forks (A54865)
New/Unused Pallet...
Mini Excavator Pallet Forks (A53316)
Mini Excavator...
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
