Need Help with quick hitch/snowblower Kubota BX2230
   / Need Help with quick hitch/snowblower Kubota BX2230
Brilliant!! I gotta believe Kevin is on to something here. Find out, somehow, from someone knowledgeable, if that hitch is for your machine. For sure, the new style would fit properly. It comes nowhere near the front axle.
Perhaps you said, did you get the snowblower separately from the tractor purchase?
I bought the tracotr used, but the package of paperwork does show the snowblower was not bought at the same time as the tractor. I guess I falsely assumed all BX tractors used the same hitch, dont get me wrong, it fits on there and its tight, but I'm realizing its definitely not the correct QH... I am just not sure if I can swing the extra cake to buy a different one unless I can sell the old one.
   / Need Help with quick hitch/snowblower Kubota BX2230 #43
Your dealer may trade with you for a few bucks, mine did.
   / Need Help with quick hitch/snowblower Kubota BX2230 #44
Sounds like you have a spare QH to sell to the OP. Problem solved all around.:D:D
I still use the 1860 to clean up around the buildings as it much easier to manuver than the big one.
   / Need Help with quick hitch/snowblower Kubota BX2230 #45
Trust me, these items are in hot demand and sell easily. Trading with a cooperative dealer works as well.
It truly sounds as if this "package" was cobbled together by someone else who assumed it would work. Sometimes, things like this happen.
You want to get all this working correctly, right? Take the initiative and make it happen. ;)
Just called, they wont trade, it seems my QH is for ONLY the BX1500, which is about 10 years old, he has no interest in taking it as trade -- $570 for the new style QH that fits basically everything.. Not sure I can swing that right now, he suggest I rig it up to work, which I somewhat have at this point, still nervous about doing damage to my machine.
   / Need Help with quick hitch/snowblower Kubota BX2230 #47
Rob,
see post 40
   / Need Help with quick hitch/snowblower Kubota BX2230 #48
Yep, running with wrong hitch is a bad idea. The drive line rolls at about 2500 RPM
Yes, and it was at full throttle last time when I had the issue and the PTO shaft hit the ground - NOT a good feeling or sound
   / Need Help with quick hitch/snowblower Kubota BX2230 #50
Call another dealer and see if you can get a better price, maybe put a wanted on Craigs List.
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
E-Z Trail 20' Head Cart (A59814)
E-Z Trail 20' Head...
JCT 48" HYD TRENCHER (A52706)
JCT 48" HYD...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58216)
2013 ORTEQ ENERGY...
CASE TV370B SKID STEER (A52706)
CASE TV370B SKID...
