Need input on a welder for a newbie
   / Need input on a welder for a newbie
Good to know. I doubt I'll be wanting to work with anything heavier than that.
   / Need input on a welder for a newbie #22
Rural king has a 140 amp welder, 4500 Watt generator for $1600
GW450001AC
No personal experience with it though
Northern tool has a 170 amp DC arc welder; 7000/6000 Watt generator for $1500. With wheels.
No experience with it either.
   / Need input on a welder for a newbie #24
Just make absolutely sure you don't overfill the fuel tank on the Hobart or the carb. can flood and cause the rings not to seat. Not covered by warranty. The Champion is most likely the same as a Miller Bobcat.
   / Need input on a welder for a newbie #25
Thanks for the heads up. I don't understand how that can happen.
   / Need input on a welder for a newbie #26
Non vented fuel cap and the fuel runs back down the vent line instead of venting or something along those lines. It happened on my friends Lincoln and the shop had 8 other's that had the same problem.
2025 CFG Industrial NT20-CZ Mini Excavator (A59228)
2025 CFG...
Forklift (A59228)
Forklift (A59228)
ALLISON TRANSMISSION (A55745)
ALLISON...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
2006 JAYCO JAYFLIGHT 30' TYPE CAMPER (A58375)
2006 JAYCO...
INOP 8ft Rotary Cutter (A57454)
INOP 8ft Rotary...
