Need some info on the 3016, 3616
   / Need some info on the 3016, 3616
and yet more questions as I familiarize myself with this series of tractors.
- what is a draw bar and what's its purpose?
- does the 16 series have draft control?
   / Need some info on the 3016, 3616 #22
Not sure about Draft control, but a draw bar is essentially a hitch on a tractor. Not the Ball style hitch to connect a automotive trailer, but more a bar with a hole in it to accept a pin or connect a chain.
-J
-J
Ahh, got it. Thank you.
   / Need some info on the 3016, 3616 #24
My Father has a 3016 Shuttle Shift and he really likes it. It is hard to beat for that size tractor. I have used it a good bit and its a much better bargain than the standard "L" series Kubota tractors. He paid $16,000 smooth for his loader included.
   / Need some info on the 3016, 3616 #25
My 3016 pulls 10,000 pounds of logs so fast, I had to add a draft spoiler.....the vortex was peeling off the bark.......just kidding.:D
Yes, on the lever (right rear fender) that raises and lowers the 3 point , you would find 2 friction knobs in the same groove; one knob on top of the lever and one knob on the bottom of the lever.
The bottom friction knob can be set (loosened, moved, & tightened) to limit how far down the 3pt lever travels; limiting the depth of the implement (making it hover).
The upper friction knob can be set (same) to limit how far up the 3pt lever travels; limiting the height of the implement.
There is also a knob at the base of the seat; the operator can control the free-low speed at which the implement can fall (if the 3pt lever is dumped).
There are some aftermarket hydraulic attachments that make the 3pt implement hover and make it move like a carnival ride. The Mahindra (like most tractors) comes with one 3pt arm with a turn-buckle that allows the implement to be tilted or leveled (side to side) and a top connecting link to adjust the attack angle.
Some snow plows and box scrapers also have devices that can limit the depth of their movement; my Rankin box scraper (like most) has teeth with several slots for depth adjustment, and some snow blades, plows, & blowers come with skids.
Ok, that made sense, thanks for the info!
   / Need some info on the 3016, 3616 #27
And there is one more; the 3pt arms have a number of positions that can be chosen. When I bought my tractor, the arms were almost touching the ground when the lever was in the all the way down position, I wanted a higher top-end so I moved the arms to the next (higher) position. "For the life of me"; I cannot remember how to do that without looking at the tractor but in theory, the arms can be positioned to only go down so far. They will float up very high so people usually choose the heaviest implements.
I'm very happy that you don't have the jerky hitch issue!!
   / Need some info on the 3016, 3616 #29
About the only piece of advice is to get some day-glo fluorescent paint and paint anything that is "loose" like turnbuckles, pins, clips, etc. a bright color like orange or red that will show up against grass, the cement in your garage floor or brown mud.
   / Need some info on the 3016, 3616 #30
NONE of the 16 series tractors have Draft control. What has been described are the stops that are in the groove of the position control to set the position of the hitch. The knob below the seat is the lowering speed control knob. Again, there is no draft control on any of the 15 or 16 series tractors. Most tractors that have draft control will have 2 levers side by side. One is the position control lever and the other would be the draft control lever.
If you want draft control, then you will need to step up to the 10, 25, 30, 35, 60 or M power machines. The Max and 16 series ( all Mitsubishi ) do not have draft control. ;)
Excellent, thank you. I did notice the two stopper screws when I checked out the tractors last Friday.
   / Need some info on the 3016, 3616 #32
I would personally stick with the Mitsubishi built 16 series! From reading posts for the last few years the Chinese built mahindra tractors have had the most problems.
Did you mean "Korean" built tractors?
   / Need some info on the 3016, 3616 #34
Check it out!
[hide] Model Year(s) Produced Horsepower Engine Type Misc Notes Photo
Mahindra 180 18 hp (13 kW) built in China by Mahindra China
Mahindra 200 20 hp (15 kW) built in China by Mahindra China
Mahindra FE204 20 hp (15 kW) built in China by Mahindra China
Mahindra 225-DI Yuvraj Mahindra
Mahindra 235-DI 24 hp (18 kW) Mahindra
Mahindra 245-DI 27 hp (20 kW) Mahindra
Mahindra 250 25 hp (19 kW) built in China by Mahindra China
Mahindra 254 25 hp (19 kW) built in China by Mahindra China
Mahindra 255-DI 25 hp (19 kW) Mahindra
Mahindra 265-DI 30 hp (22 kW) Mahindra
Mahindra 265-DI Bhoomiputra 30 hp (22 kW) Mahindra
Mahindra 265-DI Sarpanch 30 hp (22 kW) Mahindra
Mahindra 275-DI 39 hp (29 kW) Mahindra
Mahindra 275-DI Bhoomiputra 39 hp (29 kW) Mahindra
Mahindra 275-DI Sarpanch 39 hp (29 kW) Mahindra
Mahindra 275-DI TU Sarpanch 39 hp (29 kW) Mahindra
Mahindra B-275 35 hp (26 kW) Mahindra
Mahindra B-275-DI 39 hp (29 kW) Mahindra
Mahindra B-275-DI Bhoomiputra 39 hp (29 kW) Mahindra
Mahindra B-275-DI TU Bhoomiputra 39 hp (29 kW) Mahindra
Mahindra 284 28 hp (21 kW) built in China by Mahindra China
Mahindra 295 DI Sarpanch Super Turbo DLX 2009- 39 hp (29 kW)
Mahindra 300 30 hp (22 kW) built in China by Mahindra China
Mahindra 304 30 hp (22 kW) built in China by Mahindra China
Mahindra 350 35 hp (26 kW) built in China by Mahindra China
Mahindra 354 35 hp (26 kW) built in China by Mahindra China
Mahindra 355 22 hp (16 kW)
Mahindra 365-DI 33 hp (25 kW) Mahindra
Mahindra 400 40 hp (30 kW) built in China by Mahindra China
Mahindra 404 40 hp (30 kW) built in China by Mahindra China
Mahindra 445-DI Ultra 42 hp (31 kW) Mahindra
Mahindra 450 45 hp (34 kW) Mahindra
Mahindra 450 (China) 45 hp (34 kW) built in China by Mahindra China
Mahindra 450 Super 45 hp (34 kW) Mahindra
Mahindra 454 45 hp (34 kW) built in China by Mahindra China
Mahindra 475-DI 40 hp (30 kW) Mahindra
Mahindra 475-DI Bhoomiputra 40 hp (30 kW) Mahindra
Mahindra 475-DI Sarpanch 40 hp (30 kW) Mahindra
Mahindra B-475-DI Bhoomiputra 42 hp (31 kW) Mahindra
Mahindra B-475-DI TU Bhoomiputra 42 hp (31 kW) Mahindra
Mahindra 485-DI Mahindra
Mahindra 500 50 hp (37 kW) built in China by Mahindra China
Mahindra 504 50 hp (37 kW) built in China by Mahindra China
Mahindra 554 54 hp (40 kW) built in China by Mahindra China
Mahindra 555-DI Ultra 54 hp (40 kW) Mahindra
Mahindra 575-DI 45 hp (34 kW) Mahindra
Mahindra 575-DI Bhoomiputra 45 hp (34 kW) Mahindra
Mahindra 575-DI Sarpanch 45 hp (34 kW) Mahindra
Mahindra 585-DI 50 hp (37 kW) Mahindra
Mahindra 585-DI Bhoomiputra 50 hp (37 kW) Mahindra
Mahindra 585-DI Sarpanch 50 hp (37 kW) Mahindra
Mahindra 595-DI Sarpanch 52 hp (39 kW) Mahindra
Mahindra 595-DI Sarpanch Super Turbo 52 hp (39 kW) Mahindra
Mahindra 595-DI Turbo 52 hp (39 kW) Mahindra
Mahindra 605-DI 60 hp (45 kW) Mahindra same as Arjun 605-DI
Mahindra 605-DI (Chinese) 60 hp (45 kW) built in China by Mahindra China
Mahindra 605-DI PLF 60 hp (45 kW) Mahindra
Mahindra 605-DI Ultra 59 hp (44 kW) Mahindra
Mahindra 705-DI 70 hp (52 kW) Mahindra
Mahindra 1815 HST 18 hp (13 kW) Mitsubishi built in Japan by Mitsubishi
Mahindra 1816 HST 18 hp (13 kW) Mitsubishi built in Japan by Mitsubishi
Mahindra 2015 20 hp (15 kW) Mitsubishi built in Japan by Mitsubishi
Mahindra 2015 HST 20 hp (15 kW) Mitsubishi built in Japan by Mitsubishi
Mahindra 2216 Gear 22 hp (16 kW) Mitsubishi built in Japan by Mitsubishi
Mahindra 2216 HST 22 hp (16 kW) Mitsubishi built in Japan by Mitsubishi
Mahindra 2310 25 hp (19 kW) Daedong built in South Korea by Tong Yang
Mahindra 2310 HST 25 hp (19 kW) Daedong built in South Korea by Tong Yang
Mahindra 2415 24 hp (18 kW) Mitsubishi built in Japan by Mitsubishi
Mahindra 2415 HST 24 hp (18 kW) Mitsubishi built in Japan by Mitsubishi
Mahindra 2516 Gear 25 hp (19 kW) Mitsubishi built in Japan by Mitsubishi
Mahindra 2516 HST 25 hp (19 kW) Mitsubishi built in Japan by Mitsubishi
Mahindra 2525 25 hp (19 kW) built in China by Mahindra China
Mahindra 2614 26 hp (19 kW) Mitsubishi built in Japan by Mitsubishi
Mahindra 2615 HST 26 hp (19 kW) Mitsubishi built in Japan by Mitsubishi
Mahindra 2741 27 hp (20 kW) built in China by Mahindra China
Mahindra 2810 28 hp (21 kW) Daedong built in South Korea by Tong Yang
Mahindra 2810 HST 28 hp (21 kW) built in South Korea by Tong Yang
Mahindra 2815 HST 28 hp (21 kW) Mitsubishi built in Japan by Mitsubishi
Mahindra 2816 Gear 28 hp (21 kW) Mitsubishi built in Japan by Mitsubishi
Mahindra 2816 HST 28 hp (21 kW) Mitsubishi built in Japan by Mitsubishi
Mahindra 3015 HST 30 hp (22 kW) Mitsubishi built in Japan by Mitsubishi
Mahindra 3016 2010- 30 hp (22 kW) Mitsubishi built in Japan by Mitsubishi
Mahindra 3016 HST 2010- 30 hp (22 kW) Mitsubishi built in Japan by Mitsubishi
Mahindra 3215 32 hp (24 kW) Mitsubishi built in Japan by Mitsubishi
Mahindra 3215 HST 32 hp (24 kW) Mitsubishi built in Japan by Mitsubishi
Mahindra 3315 DI 32 hp (24 kW)
Mahindra 3316 33 hp (25 kW) Mitsubishi built in Japan by Mitsubishi
Mahindra 3316 HST 33 hp (25 kW) Mitsubishi built in Japan by Mitsubishi
Mahindra 3325 35 hp (26 kW) Mahindra
Mahindra 3505DI 35 hp (26 kW)
Mahindra 3510 35 hp (26 kW) Daedong built in South Korea by Tong Yang
Mahindra 3510 HST 35 hp (26 kW) Daedong built in South Korea by Tong Yang
Mahindra 3525 35 hp (26 kW) Mahindra
Mahindra 3535 35 hp (26 kW)
Mahindra 3616 2010- 36 hp (27 kW) Mitsubishi built in Japan by Mitsubishi
Mahindra 3616 HST 2010- 36 hp (27 kW) Mitsubishi built in Japan by Mitsubishi
Mahindra 3825 41 hp (31 kW) Mahindra
Mahindra 4025 41 hp (31 kW) Mahindra
Mahindra 4035 40 hp (30 kW)
Mahindra 4035 PST 40 hp (30 kW)
Mahindra 4110 41 hp (31 kW) Daedong built in South Korea by Tong Yang
Mahindra 4500 42 hp (31 kW) Mahindra
Mahindra 4505DI 43 hp (32 kW) Mahindra
Mahindra 4510 45 hp (34 kW) Daedong built in South Korea by Tong Yang
Mahindra 4525 45 hp (34 kW) Mahindra
Mahindra 4530 42 hp (31 kW) Mahindra
Mahindra 5005-DI 51 hp (38 kW) Mahindra
Mahindra 5010 2011- 49 hp (37 kW) built in South Korea by Tong Yang
Mahindra 5010 HST 2011- 49 hp (37 kW) built in South Korea by Tong Yang
Mahindra 5035 50 hp (37 kW)
Mahindra 5035 HST 50 hp (37 kW) Mahindra
Mahindra 5500 54 hp (40 kW) Mahindra
Mahindra 5520 55 hp (41 kW) Mahindra
Mahindra 5525 54 hp (40 kW) Mahindra
Mahindra 5530 4WD 54 hp (40 kW) Mahindra
Mahindra 6000 59 hp (44 kW) Mahindra
Mahindra 6000 (Barchinkar) 59 hp (44 kW) assembled in Iran by Barchinkar
Mahindra 6000 DI Mahindra
Mahindra 6010 2011- 59 hp (44 kW) Mahindra
Mahindra 6025 59 hp (44 kW) Mahindra
Mahindra 6030 Turbo 59 hp (44 kW) Mahindra
Mahindra 6110 2011- 59 hp (44 kW) Mahindra
Mahindra 6500 65 hp (48 kW) Mahindra
Mahindra 6520 65 hp (48 kW) Mahindra
Mahindra 6525 62 hp (46 kW) Mahindra
Mahindra 6530 65 hp (48 kW) Mahindra
Mahindra 7010 72 hp (54 kW) John Deere built in South Korea by Tong Yang
Mahindra 7030 65 hp (48 kW)
Mahindra 7060 Turbo 67 hp (50 kW) Mahindra
Mahindra 7520 75 hp (56 kW) Mahindra
Mahindra 7575 Arjun 2009- 75 hp (56 kW)
Mahindra 8000 80 hp (60 kW) Mahindra
Mahindra 8020 4WD 80 hp (60 kW) Mahindra
Mahindra 8560 Turbo 83 hp (62 kW) Mahindra
Mahindra Arjun 405-DI 40 hp (30 kW)
Mahindra Arjun 445-DI 42 hp (31 kW) Mahindra
Mahindra Arjun Ultra 445-DI 42 hp (31 kW) Mahindra
Mahindra Arjun 555-DI 52 hp (39 kW) Mahindra
Mahindra Arjun Ultra 555-DI 52 hp (39 kW) Mahindra
Mahindra Arjun 605-DI 60 hp (45 kW) Mahindra
Mahindra Arjun Ultra 605-DI 60 hp (45 kW) Mahindra
Mahindra C27 27 hp (20 kW) Mahindra
Mahindra C35 35 hp (26 kW) Mahindra
Mahindra C4005 DI 40 hp (30 kW) Mahindra
Mahindra Designer kit
Mahindra E40-DI 39 hp (29 kW) Mahindra
Mahindra E350 DI 35 hp (26 kW) Mahindra
Mahindra ES 25 25 hp (19 kW) built in China by Mahindra China
Mahindra FS180 18 hp (13 kW) built in China by Mahindra China
Mahindra FS200 20 hp (15 kW) built in China by Mahindra China
Mahindra FS204 20 hp (15 kW) built in China by Mahindra China
Mahindra FS250 25 hp (19 kW) built in China by Mahindra China
Mahindra FS274 27 hp (20 kW) built in China by Mahindra China
Mahindra FS400 40 hp (30 kW) built in China by Mahindra China
Mahindra FS404 40 hp (30 kW) built in China by Mahindra China
Mahindra Max 22 HST 2012- 22 hp (16 kW) Mahindra
Mahindra Max 25 HST 2012- 25 hp (19 kW) Mahindra
Mahindra Max 28 XL HST 2012- 28 hp (21 kW) Mahindra
Mahindra Shaan 25 hp (19 kW)
Mahindra Tiger Moth concept
Mahindra Yuvraj 30 hp (22 kW) Mahindra
Mahindra Yuvraj-215 2009- 15 hp (11 kW)
International Harvester Models built under licenseEdit
International Harvester Tractor Models built by Mahindra
[show] Model
Year(s) Produced
Horsepower
Engine Type
Misc Notes
Tractors built for other CompaniesEdit
Ursus Tractor Models by Mahindra (sold in Brazil)
Model
Year(s) Produced
Horsepower
Engine Type
Misc Notes
Ursus 2-50 2009- 50 hp (37 kW) built by Mahindra, sold in Brazil
Ursus 2-50M 2011- 47 hp (35 kW) Mahindra built by Mahindra; sold in Brazil
Ursus 2-75 2009- 75 hp (56 kW) Mahindra built by Mahindra; sold in Brazil
Ursus 2-75M 2011- 71 hp (53 kW) Mahindra built by Mahindra; sold in Brazil
Ursus 4-65M 2011- 65 hp (48 kW) Mahindra built by Mahindra; sold in Brazil
Ursus 4-75M 2009- 75 hp (56 kW) Mahindra built by Mahindra; sold in Brazil
Ursus 4-80M 2011- 81 hp (60 kW) Mahindra built by Mahindra; sold in Brazil
Ursus 4-85M 2009- 85 hp (63 kW) built by Mahindra, sold in Brazil
Other ModelsEdit
Mahindra combine -
ReferencesEdit
↑ Farm Equipment Manufacturers | Farm Equipment | Tractor Equipment Manufacturers - Mahindra
↑ Farm Tractors | Agricultural Tractors | Mahindra Tractors - Mahindra
↑ 3.0 3.1 3.2 3.3 3.4 http://www.mahindra.com/mediaroom/Fact/fesOverview[1]..pdf
http://www.mahindra.com/Heritage/milestonesyearwise.htm
↑ Mahindra Tractor - Compact tractors, utility tractors, farm tractors, ag tractors, attachments, implements & farm equipment - all built tough!
↑ 6.0 6.1 Mahindra Corporate
↑ ::: Welcome to Mahindra Tractors :::
News
News | Mahindra
↑ PTL continuous expansion collaborations with KOEL
↑ PTL-2006
↑ 12.0 12.1 China Tractors | Mahindra USA - Mahindra
Mahindra Tractors| Farming Machinery & Agriculture Equipment | Agri Prosperity
↑ Agricultural Tractors | Farm Equipment Manufacturers - Mahindra Tractors
External linksEdit
Wikimedia Commons has media related to:
Mahindra tractors
Mahindra Corporate webpage
Mahindra Tractors webpage
Mahindra Australia
Mahindra USA webpage
Mahindra's in Iran
Mahindra Europe
Mahindra Gujarat webpage
ITMCO webpage
[show]v · d · e
Mahindra Group
[show]v · d · e
Mahindra Tractors
[show]v · d · e
List of Tractor Manufacturers (Internal Combustion engined)
[show]v · d · e
List of Engine Manufacturers
[show]v · d · e
List of Agricultural machinery manufacturers
This page uses some content from Wikipedia. The original article was at Mahindra Tractors. The list of authors can be seen in the page history. As with Tractor & Construction Plant Wiki, the text of Wikipedia is available under the Creative Commons by Attribution License and/or GNU Free Documentation License. Please check page history for when the original article was copied to Wikia
Start a Discussion Discussions about Mahindra Tractors
You can find discussions about everything related to this wiki on Tractor & Construction Plant Wiki Forum!
Categories:
Tractor manufacturers of India Merged companies Agricultural machinery manufacturers Mahindra Companies founded in 1965 Engine manufacturers of India International Harvester Companies of India Add category [Configure Reference Popups]
Advertisement | Your ad here
Photos
Add a Photo
31,771PHOTOS ON THIS WIKI
See all photos
See all photos >
Recent Wiki Activity
List of Yanmar tractors
created by Scoty6776 1 minute ago
855 UXT
edited by BulldozerD11 2 minutes ago
Brutus
edited by BulldozerD11 1 day ago
List of named vehicles
See more >
Around Wikia's networkRandom Wiki
[ ENTERTAINMENT ]
About Community Central Careers Advertise API Contact Wikia Terms of Use Privacy Policy Content is available under CC-BY-SA. Mobile site
Watch our I Frankenstein interview with Aaron Eckhart!EntertainmentVideo GamesLifestyle
   / Need some info on the 3016, 3616 #35
Some of them just say Mahindra, not sure where there built, perhaps in India? I'm not sure.
   / Need some info on the 3016, 3616 #36
As far as new Mahindra tractors for sale in the USA, the Max and 16 series tractors are built by Mitsubishi in Japan. The 10 series tractors are built by TYM in Korea. Everything else listed on their website is made by Mahindra in India. There are some Mpower tractors not yet shown that are also built by TYM in Korea.
The Mahindra plant that is in China no longer produces tractors to be sold here in the states.
   / Need some info on the 3016, 3616 #37
In my opinion, that's a good thing!
   / Need some info on the 3016, 3616 #38
I agree. They tried to make a very cost inviting tractor. It simply did not work out as had been planned or hoped for.
What they have now and will have in the near future is going to make for a pretty nice lineup. There is always room for improvement, but it is at a slow rate and not just for Mahindra, but for them ALL in my opinion. ;)
Need shipping info!!!
I need some info for a hauler to ship a 3316 tractor. I'm thinking about using USHIP to ship a tractor from AR to NM but I'm open to ideas
Can someone with 3016/3316/3616 with a BH+Loader give me the dimensions? I need length, width, height. The height seems to be a sticky point due to the backhoe. For the weight, I came up with 4700 lbs.
Thank you.
   / Need some info on the 3016, 3616 #40
I have been very happy with my geared 3636 with FEL. I was lucky enough to find one last summer with only 30 hours on it which lowered the price enough that made the deal work for me. I stll need to get the 3616 tires filled, but I think it feels more stable than the Kubota B3200HST going down a hill with a full bucket, even though the tires are filled on the Kubota. I've put another 50 hours on it since I got it and have had no problems. I did have to buy a new oil filter wrench to change the filter due to limited space.
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
207270 (A52708)
207270 (A52708)
Adams 16T Tender Body (A61307)
Adams 16T Tender...
2022 New Holland C327 Compact Track Loader (A61306)
2022 New Holland...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
