Need to replace altenator on 1986 1210
   / Need to replace altenator on 1986 1210 #1
Jacey
Ford 1210
Is there a good online resource and a good brand name to look for? This is a 1986 model 1210 NH. Thank you for any advice…price was crazy I thought at Napa.
   / Need to replace altenator on 1986 1210 #2
If you have any skills buy a one wire delco and make brackets
I don't but my buddy does. Why do you recommend this choice?
   / Need to replace altenator on 1986 1210 #4
You need to look at the backside of the current alternator to see if it's a one wire or multiple wires. A one wire alternator has the voltage regulation built into it, whereas a multiple one uses an external voltage regulator. Far as buying from NAPA, you'll do much better at a discount auto parts store and buy a rebuilt one not a new one. Nothing really to go bad inside one except the slip ring brushes which last a very long time and the diode bridge which also lasts a long time.
I would consult your owners manual to ascertain the output of your present one and then buy a comparable one with the correct drive pulley and if necessary fab the brackets to fit.
Just did that with my 02 Kubota M9 open station. Had a 60 amp one wire on it and the front bearing got noisy so I replaced it with a 100 amp unit with again, internal regulation and I paid less than 65 bucks for it from my buddy who owns a rebuilding business. I wanted the additional amperage because I added some night time illumination to it. They will want your old one in exchange however so expect to pay a refundable core charge which you get back when you turn in the old one. In my case, no core charge because it's a friend of mine but he will get my old shot one anyway at some point.
Same deal applies to brake calipers on your vehicle. I have a buddy that rebuilds brake calipers for a living. He gets bins full of old, leaking nasty calipers and then puts them in a big oven and melts all the components out of them (which he sells to the local scrap yard) and then he bead blasts them and replaced all the melted out components with new stuff and sells them back to the auto parts retailers.
He makes a big buck doing that and has a couple full time employees as well. Recycled and refurbished calipers are just as good as new ones and the same applies to alternators. He does them as well.
His company name is SPB rebuilders btw. Heck of a racket. I get my calipers direct from him and did so with the new rebuilt alternator as well.
Nothing to wear out in one except the diode bridge and possibly the bearings (in my case) and the internal regulator if it has one.
   / Need to replace altenator on 1986 1210 #5
The 1210 alternator is externally regulated. Do yourself a favor, do a little trouble shooting. It could be the regulator as well as anything. If it does turn out to need an alternator, don't start looking for a way to mount a one wire. There are plenty of replacements available in the $100 range.
Thank you for that information. I do have someone local who can rebuild it, but I'd have to take into another town. Meanwhile I was advised to get a solar trickle battery charger and just keep the battery up that way. I think it attaches to the hood. Sounds like a pretty brilliant plan for now…and not nearly as expensive as an alternator rebuild or otherwise.
   / Need to replace altenator on 1986 1210 #7
I worry about people who can afford a hobby tractor but cannot afford to replace a shot alternator for under a hundred bucks.
Your concern is touching, but you have no earthly way to know anything about what a nearly 40 year old "hobby" tractor was used for, how it was paid for…or that the local Napa wants over 239.00 for something that just requires a battery to get running. The inital question was recommendations, and I'm pleased by all the responses from people I really DO think must care about getting this fixed.
BTW…it brought out the local community around me too…and that's a ****load more valuable to me that being able to plunk down 239.00 for an overpriced item just because I can.
Now I can throw a party and have a get together on the other side to show my appreciation. :)
   / Need to replace altenator on 1986 1210 #10
My Kenbota had a Dynamo with a regulator. I canned all that and went with a 1986 Subaru alternator. It's not much bigger than the dynamo but has about 4-times the output. Just what I needed to run my extra lights.
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59575)
2020 INTERNATIONAL...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
2019 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2019 MQ POWER...
2024 Frontier FL1061S Hydraulic Flail Mower (A56438)
2024 Frontier...
TORO GREENS MOWER (A56857)
TORO GREENS MOWER...
