Neighbor removed my property line pin
   / Neighbor removed my property line pin
In the interest of good relations, could you assume that the person who moved the telephone riser accidentally dug up the pin? Maybe the neighbor had nothing to do with it.
Possible but highly doubtful. Like myself, he does all his own work. He even trenched and laid the 1K' of underground cable for his cable TV when it became available years ago.
My only real concern is whether or not I should confront said neighbor about the pin. If I choose to ignore what's been done, can it come back and bite me down the road? I can't see how, but given the way the legal system operates today??
Here's a couple pics...one showing the corner where the pin was located on his side of the trees. The other pic shows the location of some of the trees versus the front of his house. They're located about 30' from his front door. He wasn't to happy about the placement, but given what had occurred causing me to plant them in the first place...he should have given more thought to the placement of his house when he built it. He owns 4.5 acres and easily could've built further back.
   / Neighbor removed my property line pin #13
Holy Moly, I would love to mow grass that nice!
   / Neighbor removed my property line pin #14
If you're concerned about future legal ramifications, go talk to a lawyer that knows the law in YOUR AREA. We're just a bunch of armchair quarterbacks on here. You can do this without your neighbor knowing. That way, if its not an issue, you can just let it slide. You obviously don't want an ongoing dispute with your neighbor, since you said you took the effort to bury the hatchet before. No sense in rubbing salt in old wounds if there's no benefit.
Keith
   / Neighbor removed my property line pin #15
The survey itself was never disputed. In fact the neighbor just played stupid when the actual property line location was established. In fact I clearly remember the day we were discussing his phone line riser. He built his home a year earlier than mine and he "thought" the property line was "here"....emphasis on the quotation marks
I have very little sympathy for those who build near a property line without surveying first. When I built a fence around my property, I bit the bullet and paid $600 to have my place surveyed. Every pin was where it was supposed to be, but my neighbor had hinted that he thought a previous owner had moved some of the pins, and I wasn't about to take a chance of him arguing with me in the future. I understand that neighborly peace can be a more important principle than the property line itself, so I'm not questioning your decision to let it slide, but I have also seen too many of these cases where a person's generosity with regard to property rights turned out to be his undoing. I hope that you don't become one of them.
   / Neighbor removed my property line pin #16
This^.
I might call the surveyor who did the survey and see what it would cost to have him re-set the pin and then pound in a 4' T post next to the pin (inside your line) till its 4-6" underground... Hard to accidentally dig out something like that.
As it sits, I would be surprised if there is a way to prove that it was him who dug it up and I wouldn't start something where the only winners will be the lawyers...
Keith
Good point, but I somewhat disagree with the armchair Q'backs comment ;) because I've seen some of you guys put up info that someone may not think about. There's been a number of threads involving property lines that prove it.
   / Neighbor removed my property line pin #18
First things First- don't make assumptions. You have no real way of determining who actually removed the marker.
Sounds like you have all of the documentation from the surveyor. If it is really bugging you- contact the surveyor and "ask" him about the pin/ tell him you can't find it. He may be interested in the situation since he may have some vicarious liability.
Otherwise, let sleeping dogs lie-
:2cents:
We're on the same page!!
:2cents:
You're absolutely correct...I have no proof just an assumption.
But more importantly...instead of getting a lawyer involved at this stage (not that I believe I need one yet), I like the suggestion of contacting the surveyor about not finding the pin.
Thanks!
2014 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A60460)
2014 Chevrolet...
2014 Ford F-350 4x4 Ext. Cab Palfinger PSC4216 2 Ton Crane Service Truck (A60460)
2014 Ford F-350...
JCB 220XLC-4F EXCAVATOR (A60429)
JCB 220XLC-4F...
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
KUBOTA SSV65 OPEN STATION CAB (A52706)
KUBOTA SSV65 OPEN...
2014 Chevrolet Impala Limited Sedan (A59231)
2014 Chevrolet...
