New B2620 w/ FEL, Backhoe & 54" MMM
   / New B2620 w/ FEL, Backhoe & 54" MMM
Yeah I understand your frustration. One would hope you could use all three if desired. Sounds like the BX25 is superior in this aspect... Something else for me to consider in my shopping.
Thanks for your info and feedback! I'm sure the install and removal of the arm will speed up with practice. How many parts must be installed?
First I have to remove a set bolt that locks the rod that the 3 pt arms attach to. Once this bolt is free, I have to work the rod to the right. Then I mount the left 3 pt arm and connect the locking pin to the 3 pt arm to keep the left arm in place. Then I have to work the rod back to the left and re-set the bolt that locks the 3 pt rod in place. Then I attach the left 3 pt arm to the left lift as well as attach the sizing linkage. I was able to do it all in about 10 minutes this weekend and hope it will get even easier when the rod loosens up.
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51691)
2001 Dodge Ram...
1997 Ford F-250 Pickup Truck (A53117)
1997 Ford F-250...
2015 Freightliner Cascadia 125 T/A Wet Kit Day Cab Truck Tractor (A51692)
2015 Freightliner...
2017 Hammerhead Off-Road Utility Cart (A51691)
2017 Hammerhead...
2013 Chevy Silverado 2500 HD (A53473)
2013 Chevy...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
