New member ...looking to buy 24 to 30 hp tractor
   / New member ...looking to buy 24 to 30 hp tractor
Thanks Tony. I was wondering if the 27 was the same size frame as the 30. Didn't know the 35 was the same size family . I agree, the Kioti is a much better built tractor from what i saw. Now i will have to look at the 35 as well. I am going to go look at the Mahindra 3016 though. Very hard to find used models of Kioti and Mahindras...
   / New member ...looking to buy 24 to 30 hp tractor #62
plus the HST has a rocker pedal which means no lifting your foot to change direction..
Think long and hard about this as having your foot and leg locked into that one position to operate that pedal is more of a problem for many of us who don't like the rocker than having to lift your foot to get to the other pedal. I find after about a half hour with just about every rocker pedal I tried that my knee starts to hurt and my leg gets numb and stiff. Now I do have problems with my knees but having the ability to really vary my legs position and in general having my leg out more in a more relaxed position has always been the most comfortable for me. Your mileage may differ but I do have a friend who at first thought he liked the rocker, brought home a Kubota L3200 then within a year decided he couldn't stand it anymore and had to replace it with a new JD that has dual pedals.
Other than the rocker the CK would have topped my list had I stayed in the 35HP range so I do understand your picking it over the others. I really wasn't as impressed with the Mahindra as everyone else seems to be. It seemed their fit and finish was a hit and miss depending on the model. Looking back it seemed the 3016/3616 were all solid and finished fairly but didn't really give me a feel of comfort and the 3535 was very comfortable but the finish of the machine was hit and miss not to mention having one break during a test ride was not a good sign. I haven't looked at a branson since they had the century line and don't know of any close dealers so I didn't bother. For me the best contenders when shopping balanced out between all my concerns then bringing price into it were the Kioti, TYM and LS. With the smaller sized tractors I probably would have went out on a limb and purchased the TYM 353 had I stayed in the 30-35HP range but I got a real fair deal on the DK40 and in all honesty it is better suited to my needs so I chose the Kioti. GO look at the others and get a second look at everything you feel is good as many folks miss things the first time around that for some reason seem blatantly clear on the second visit.
   / New member ...looking to buy 24 to 30 hp tractor #63
The only difference between the CK27(25), 30, and 35 is the HP. The controls, size, and hydraulics are all identical. The weight may differ by a few 100 pounds though, I forget exactly. If you like the layout of the CK30, you'll like the layout of the CK27 and CK35 too. As I said, the price difference is almost negligible between the 3.
I do intend to go back out looking. Not in a dire need to get one right now unless i find a good deal. The Branson is a solid tractor and i will have a dealer close when we move to Tenn. Since the 5 acres is on hilly property, weight and width is a key factor. Not sure i want something that is 48 in. or less in width. Good point on the rocker pedal !! The Kioti dealer has told me they quit making the CK27....
   / New member ...looking to buy 24 to 30 hp tractor #65
The 3016 HST has a rocker. It is slightly longer than your foot. I have no issues with the rocker. I've driven rocker and double pedal HST's and prefer the rocker. With the 2 pedal system it's easy to move your foot from side to side and hit both pedals at the same time. The side to side foot motion isn't comfortable for me as I never move my leg which can be uncomfortable when using it for hours at a time.
   / New member ...looking to buy 24 to 30 hp tractor #66
I agree with Paul, really think the rocker pedal idea through. When I've used them I started getting pain in my knee and thigh after a short while. With the dual pedals I can operate a machine all day and at least with my JD's there is no need to lift your foot, just rotate your ankle to the other pedal. Very natural just like the gas and brake pedal in a car.
   / New member ...looking to buy 24 to 30 hp tractor #67
I have only extensively used rocker pedals, but I can't see my self on a two pedal setup for 2 reasons. Half of my snow plowing is done facing backward, and while I suppose it is possible to press the reverse pedal forward while facing backward, I find it better with the treadle, as I can turn around and my foot is right on the reverse side of the rocker. Also, I have big feet, and often where big boots. I think I would constantly find myself hitting the wrong pedal or both, because my boot hadn't cleared one or the other. No such issue with the treadle.
Kioti calls the CK27 the CK25 sometimes, same tractor. The CK20 is no longer made, replaced by the CS2410, and the CK2510. The Tier IV CK series will be called the CKXX10, but will still be the same tractor.
   / New member ...looking to buy 24 to 30 hp tractor #68
   / New member ...looking to buy 24 to 30 hp tractor #69
Rocker pedals prove fine for most. I've only had rockers starting with my Toro Wheel Horse tractors and now with my Mahindra 2516, and Bobcat CT230 (the almost twin brother to the Kioti CK30).
I'm 59 years old, 6'6" tall and weigh 270 lbs. with tired size 15 feet and and bad knees. Rocker pedals work just fine for this old Whisker-Puss.
   / New member ...looking to buy 24 to 30 hp tractor #70
Rocker or two pedal is a personal preference. You'll find folks on both sides of the fence on that. I prefer 2 pedals, but that wouldn't sway me from buying a tractor with a rocker. I think you'll get used to which ever. And I think you can use a rocker like it's 2 pedals if you want.
As for the Kioti's. CK25/27/30/35 are identical tractors with different engines. That is the only difference. Identical tractors otherwise. If you plan to use the PTO a lot, I suggest the 35 HP. Always good to have as much hp as you can. I have the CK25 in shuttle. Great for ground engagement. I only use the PTO for a chipper and post hole digger. Plenty of power for that. HST robs a few HP too. But, as was suggested 60" mowers are the way to go and that works best with more HP. drag, pull, push implements, you wouldn't notice a difference in any of them.
I have the industrial tires and hate them. Wish I had gotten AGs. The industrials are terrible in the mud and snow. Tough as can be and look good. But, if you want traction in the mud get Ags. If you care more about snow and lawn impact, get turfs. Load the tires and set the Ags as wide as they will go (they adjust to give you the widest stance). That's a really go price on the CK. I would wait too long on that one.
1997 PETERBILT 387 CAB CHASSIS TRUCK (A59575)
1997 PETERBILT 387...
2015 Ford F350 XL (A57148)
2015 Ford F350 XL...
2021 MULTIQUIP 25 WHISPERWATT DIESEL GENERATOR (A59823)
2021 MULTIQUIP 25...
2014 Mercedes GL450 AWD SUV (A56859)
2014 Mercedes...
Murray Push Mower (A57453)
Murray Push Mower...
LIGHT TOWER (A56857)
