New Tractor Purchase JD 2305
   / New Tractor Purchase JD 2305 #31
My understanding is that the mechanical lift uses the 3-point hitch lifting mechanism and the independent lift is hydraulic. Ther is another thread related to this subject. It seems most like or would like the mechanical lift over the independent.
   / New Tractor Purchase JD 2305 #32
   / New Tractor Purchase JD 2305 #33
Strange - the dealers I've spoken to have all recommended it (and they have to order the tractor so it's not like they are trying to move what they have on the lot). It's not like it's a high-buck item either, just a couple hundred bucks. Hmmm...
I would think it would be bothersome to have the 3-pt moving up and down it you are mowing with the ballast box on or if you get a rear bagger system of some sort (JD, Trac Vac).
I'll believe I'll be ordering a 2305 soon, now I'll have to think about this...
Scott
   / New Tractor Purchase JD 2305 #34
Scott
   / New Tractor Purchase JD 2305 #35
From what it sounds like, the dealer found that the independent lift was being oversold - in other words, people thought it worked better than it actually did in practice. As for the ballast box point, my dealer conceded that you probably do not want to have the ballast box on when mowing otherwise you may bottom out especially when climbing a steeper incline. Nevertheless, I pulled the trigger tonight and expect the machine soon, equipped with the mechanical lift.
   / New Tractor Purchase JD 2305 #36
2007 PETERBILT 379 TANDEM AXLE SLEEPER TRUCK (A54607)
2007 PETERBILT 379...
2025 380 Mini Track Loader Stand-On Skid Steer (A53421)
2025 380 Mini...
78'' root grapple (A53421)
78'' root grapple...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A53473)
2019 Krause...
2007 Ford F750 Forestry Chipper Truck (A52377)
2007 Ford F750...
