New Tractor Purchase JD 2305
   / New Tractor Purchase JD 2305 #31
My understanding is that the mechanical lift uses the 3-point hitch lifting mechanism and the independent lift is hydraulic. Ther is another thread related to this subject. It seems most like or would like the mechanical lift over the independent.
   / New Tractor Purchase JD 2305 #32
   / New Tractor Purchase JD 2305 #33
Strange - the dealers I've spoken to have all recommended it (and they have to order the tractor so it's not like they are trying to move what they have on the lot). It's not like it's a high-buck item either, just a couple hundred bucks. Hmmm...
I would think it would be bothersome to have the 3-pt moving up and down it you are mowing with the ballast box on or if you get a rear bagger system of some sort (JD, Trac Vac).
I'll believe I'll be ordering a 2305 soon, now I'll have to think about this...
Scott
   / New Tractor Purchase JD 2305 #34
Scott
   / New Tractor Purchase JD 2305 #35
From what it sounds like, the dealer found that the independent lift was being oversold - in other words, people thought it worked better than it actually did in practice. As for the ballast box point, my dealer conceded that you probably do not want to have the ballast box on when mowing otherwise you may bottom out especially when climbing a steeper incline. Nevertheless, I pulled the trigger tonight and expect the machine soon, equipped with the mechanical lift.
   / New Tractor Purchase JD 2305 #36
2020 INTERNATIONAL RH613 MID-ROOF SLEEPER TRUCK (A53843)
2020 INTERNATIONAL...
2008 FORD F350 XL SUPER DUTY DUMP TRUCK (A51406)
2008 FORD F350 XL...
2008 Caterpillar 303.5C Mini Excavator (A52377)
2008 Caterpillar...
2013 Bobcat T180 (A47477)
2013 Bobcat T180...
CASE 621G (A53843)
CASE 621G (A53843)
2019 KENWORTH T880 HYDROVAC (A53843)
2019 KENWORTH T880...
