New trailer discussion & ideas
   / New trailer discussion & ideas #21
   / New trailer discussion & ideas #22
I recently finished my trailer research and what I settled on was a 20', 14k#, low-profile, tilt-deck from Load-Trail. The TL14:
*NEW* Low-Profile Tandem Axle Tilt Deck 14,000 Lb 6" Channel Frame Load Trail Trailer Manufacturing
I chose it because the tilt deck design means easy loading and unloading and no messing around with ramps. The 4' stationary section gives you a place to strap down an implement or a pallet and still be able to tilt the deck. It's more pleasant to load and tow since it's so close to the ground.
I considered power tilts and a lot of other stuff. In the end, this was my favorite option. If your M6800 fits between the wheel wells, I think it would be a good option for you.
   / New trailer discussion & ideas #23
I have a PJ 14K full deck tilt trailer. They also make full tilt deck over trailers that would work for you.
PJ Trailers - Deckover Tilt (T8)
First off thanks to everyone for helping, I must not be as good at searching as I thought I was.
George that is the trailer I had settled on except it was a deckover and if the dealer had one when I got there I would have gotten it. but now with all these options I have, I will have to wait and see.
   / New trailer discussion & ideas #24
Did you ever say what you were towing with? I wouldn't have a deckover behind anything smaller than a modern 1-ton truck. They're heavier and putting the load up higher makes them less stable going down the roads. Even then, if I can get away with it I'd rather have the deck between the wheels.
   / New trailer discussion & ideas #25
2008 GMC 3/4 Ton
   / New trailer discussion & ideas #26
If it is a gooseneck the 3/4 ton will handle it just fine.
Here is my 2006 GMC 3/4 ton with the heaviest load that I ever puled. Hauled from Rogers, AR, to west of Oklahoma City in September of 2009.
12,640 on the deck, 3440 on the ball, 14,200 on the axles. Was very stable.
attachment.php
attachment.php
   / New trailer discussion & ideas #27
I agree. No need for a 1 ton for the right size trailer. I pulled a 7 ton 25' deck over gooseneck daily with an '04 GMC 2500HD. Truck was rated for 15,400. Never had any issues even once when I overloaded it with a 15,000# ish scissor lift that I hauled 80 miles. Plenty of options of deck over that are well suited to 3/4T SRW trucks
   / New trailer discussion & ideas #28
I am not saying it will be legal or by the books but 3/4 tons will pull large loads fine. I have scaled 27k gross with my 3/4 ton and gooseneck dump trailer when they loaded too much at the gravel quarry. I hauled it 30+ miles and it towed and stopped fine. I wouldn't make a habit of it but they are capable trucks.
   / New trailer discussion & ideas #29
Thanks, I have considered a goose neck but my truck is not set up for one and I am considering a new truck in the next three years so I don't know if I want to upgrade this one. it is a 2008 with only 98K miles on it. I have pulled 14K on it with no problem.
   / New trailer discussion & ideas #30
I have noticed the deck-overs look heavy too. They are pretty much two trailers, a frame underneath to hold the suspension and the tongue, and another frame above for the decking.
8' LARGE FENCE POSTS (APPROX. 20-25 PC) (A54757)
8' LARGE FENCE...
2014 Volkswagen Jetta Sedan (A55758)
2014 Volkswagen...
2009 Honda Pilot AWD SUV (A53424)
2009 Honda Pilot...
2016 Ford Fusion Hybrid Sedan (A55758)
2016 Ford Fusion...
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
2005 FONTAINE 48 FOOT FLATBED (A53843)
2005 FONTAINE 48...
