New YM1700 has questions
   / New YM1700 has questions #21
Norm,
Thanks for the info. I used the new Prestone 50/50 mix and dilluted with distilled water, but I threw the jug away. I don't remember seeing a chart on it, but I will look when I buy more coolant and oil.
   / New YM1700 has questions #22
Attached is the entire chart.
   / New YM1700 has questions #23
Norm,
That was quick! Thanks for the chart.
Now; how many quarts in a 1700 radiator?
   / New YM1700 has questions #24
I don't have my manual handy, but I believe the 2000, which should be the same is only 1 gallon.
   / New YM1700 has questions #25
The truth is, I never checked the coolant. I replaced the coolant early last winter with the 25/75 mixture when I put the block heater in the lower radiator hose, and haven't messed with it since. I don't have a checker, but now that I know how close I am flirting with disaster, I will definitely get one SOON. I need that tractor to till this spring, and I am still hauling fire wood.
I just wanted to update the progress for the benefit of outhers who may experience this problem. I started up the engine from cold and ran it about 5 minutes the temp light came on again. I placed a thermometer in the radiator and measured a temp of 140 degress. I drained the cooling system and filled it with cold water and the temp light remained on. I was pretty much convinced by then the temp sensor must be bad. I flushed the cooling system with Prestone flush and replaced the coolant with a 25/75 coolant/distilled water mixture. I started up the engine from cold and ran it about 5 minutes the temp light came on again.The engine was definetely not hot. I again and measured a watertemperature of 140 degrees. Having satisfied myself the the engine was not overheating I ran the tractor for about 30 minutes using my box blade while carefully monitoring the engine. It was funning fine. I shut it off and place the thermomoter in the radiator again and measured a temp of 205.
I have a ordered a temp guage from Hoye and hopefully will install it next weekend if I can figure out how to cut the hole in the dash without scratching it up.
   / New YM1700 has questions #27
u need a good metal hole saw... find out what dia hole u need go to lowes or home depot and ask for a metal hole saw!
They attach to ur drill..... easy as pie or pi......
   / New YM1700 has questions #28
Autozone carries 1 1/2" gauges that will fit in your existing holes. They come in a triplet set and you can use them all, about $30 plus about $5 for an adapter kit.
2010 KMC 3376 Peanut Combine (A56438)
2010 KMC 3376...
HYDRAULIC WINCH RACK (A58214)
HYDRAULIC WINCH...
2024 CATERPILLAR 306CR EXCAVATOR (A60429)
2024 CATERPILLAR...
15200 (A56857)
15200 (A56857)
2023 GREAT DANE FLP-0024-00053 53FT FLATBED TRAILER (A59905)
2023 GREAT DANE...
2022 BOBCAT MT100 STAND-ON SKID STEER (A60429)
2022 BOBCAT MT100...
