SkunkWerX
Platinum Member
Trailer is the way to go.
Lower to ground + no wheel wells = happy trip and happy unloading.
Trailers also have lots of tie-down points.
If the trailer is low enough, and they load the mower tail-wheel first, you can back up to the trailer and hook up to the 3PH. Might need a couple 2x blocks of wood under rear tractor tires, but I've done it with implements before.
For box blade, have them load it onto a peice of scrap plywood, use a big pry bar, slide a couple pieces of rebar or steel pipe under it, and roll it to the back of the trailer. Then, same thing, might be able to hook up, 3PH style.
If you have a curb, gulley or hill that is accesible, you can park the trailer such that it's only inches off the ground.
Have fun.
Have fun.
