No more V8 in F150?
   / No more V8 in F150? #211
   / No more V8 in F150? #212
   / No more V8 in F150? #213
Someone runs without the dipstick, blows 4 of the 6 quarts of oil out, and you hold the engine design at fault? Are you brainless or just read the title and immediately thought it was some design flaw? Read the description, the owner ran it out of oil. Do you honestly expect your engines to run without oil?
   / No more V8 in F150? #216
Such an opportunist...
Just wouldn't want you F150 guys getting hurt in your superior truck... Might need those brakes with all that V6 power and speed. HS
   / No more V8 in F150? #217
I must admit, that was funny
   / No more V8 in F150? #218
All brands have recalls. In a way they are a good thing to a point because the company is stepping up and making it right. GM is by far the worst. I know guys with 2 year old trucks that have had nearly 10 recalls an in one case they disabled a system, heated WWF Res, and gave him a check for something like $50. I would be livid. They would end up buying my truck back if they could not keep each and every option it came with in working order during the warranty period.
Chris
   / No more V8 in F150? #219
Agreed. Ford seems to handle such things a bit better than some others.
Not to mention the fact that 271,000 trucks may sound like a lot of trucks to fix, and it also makes up a year or more worth of sales for some companies. But for Ford, that is a TINY drop in the bucket compared to the total number of trucks they built through 2013-2014. Not sure exactly how many of the 743,851 F series trucks sold in 2014 are F150s as compared to the F250 or F350; last I heard was several years back stating that F150s sold more than F250 and F350 combined. If that still holds true, that means they sold well over 350,000 F150s in 2014 alone. The production numbers for 2014 were significantly lower than normal due to plant shutdowns for retooling for the 2015 models. In 2013 they sold even more... 217,000 from 2013 & 2014 is nothing...
It is a minor recall for Ford, so that's not why it's in the news. It's in the news because it is a major safety concern for the drivers of those trucks. It also has nothing to do with the lack of a V8, so it doesn't really apply to the conversation unless all you want to do is nit-pick Ford for ANYTHING at all.
   / No more V8 in F150? #220
I wouldn't say any one is that much above the others. The numbers can change any day. It comes down to them all being at the mercy of suppliers, but they choose and monitor the quality of the suppliers so it still falls on the manufacturer. I'm just pleased to see them issue recalls and do the right thing by fixing problems as they are found.
2022 New Holland C327 Compact Track Loader (A55302)
2022 New Holland...
JMR 40" Mini Root Grapple (A53316)
JMR 40" Mini Root...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
2012 Buck Verano Sedan (A55758)
2012 Buck Verano...
2006 John Deere 120C Hydraulic Excavator (A53421)
2006 John Deere...
Exmark Lazer Z 96" Wing Zeroturn (RUNS) (A50775)
Exmark Lazer Z 96"...
