Just in case there has been any mis-understanding about the "NOISE", the grinding noise I have referred to is NOT like what you would hear if your brake shoes on your car were wore out. The NOISE sounds like trying to shift gears without using the clutch.
I pulled the inspection plate. No burnt smell, no dust or metal particles in bottom, release bearing (Throw-out?) was not stuck or rough when turned by hand. Release leavers ~ .15 inch from bearing. Clutch pedal free play about 2.5 inches.
I adjusted pedal until release leavers were about .05 from bearing, same noise occured. Then adjusted until leavers were about .25 from bearing, same noise.
I did not measure finger spacing on main or pto clutch as I had nothing with me to measure accurately with.
I do not understand why with tractor running, you can press clutch, shift to a gear, no noise, until you release clutch, or press clutch while in gear and noise starts at top of pedal and quits at bottom. I could understand pressing clutch, and get noise while shifting to a gear.
Read manual several times, Read post on JOHNS site, Service Bulletin 11 on Tractor-Outlet, and pics you supplied.
I am about to try to adjust Main clutch later this PM. Will adjust 1/2 turn TIGHTER on each finger and try it, then if necessary another 1/2 turn. Will check release leaver space from bearing each time, and adj pedal also.
Any warnings, hints, instructions etc. would be greatly appreaciated before I start.
Yall are a great bunch of people, and all comments have been appreciated.
Dave in MS
