Noise level of a Kioti diesel?
   / Noise level of a Kioti diesel? #1
bbse
Platinum Member
Nashville, TN
Mahindra 3325
I am just curious about something. I have a 3054 and it has the TD1400 engine. The only thing I have to compare it to is the Kubota 3010 I used to have and my brothers L3450. I think the engine is rather noisy. I guess, I would have to say it seems noisier when it is not under a load. I don't think about it much when I mowing. But when I am moving dirt I let it run around 2000-2200 rpm while transporting and it seems very... well rattly...rattling. Since I have nothing to compare it too I would like to hear from others(maybe dealers) and hear your comparisons. I am not having a problem. I just rebuilt this engine and it has only 18 HRS on it. Runs great, pulls stronger and seems to be getting stronger every day. I did most chores the other day at 2300rpm no problems. Maybe the muffler is worn out. I may take that apart and check it.
   / Noise level of a Kioti diesel? #3
At idle, I can hear a metal on metal rattling from the front somewhere around the engine. I had no idea what it was until I did a walk around and noticed that the loader level rod was vibrating and rattling in the sleeve. I grabbed a hold of it and the rattle went away.. I would check for stuff like this. Other than that, I have no idea. /forums/images/graemlins/cool.gif
   / Noise level of a Kioti diesel? #4
   / Noise level of a Kioti diesel? #5
I know what you a talking about. My dk45s has a distinct diesel rattle too, not as bad now as it was when it was new, seemed to quiet down some after about the first fifty hours or so. i have the same rattle that you are talking about with the bucket level indicator rod tattling, the tow bar also rattles sometimes. the kioti i think is noisier that some other tractior brands, but for a very distinct diesel rattle pull upside a dodge cummins pickup with the 24 valve engine. those guys have to shut the engine off just to order at Mcdonalds.
   / Noise level of a Kioti diesel? #6
   / Noise level of a Kioti diesel? #7
I have been able to locate a huge source of racket at idle and probably higher rpms. Just push in the clutch and a huge source of noise goes away. Maybe it is the HST tranny, don't know, but the noise level is hugely reduced. I have even latched the clutch hold down hook and the engine itself just purrs.
   / Noise level of a Kioti diesel? #8
Of course being a 3054 I don't have HST /forums/images/graemlins/frown.gif. This is definitley a diesel thing and it is a normal thing. I was just curious as to how loud it was compared to other Kiotis and/or to other brands if someone had direct access or experience. I also had a 98 Dodge, 12 valve head, and I had to shut it down to order lunch at the drive thru. I had a 01 Chevy Duramax and it had a ping but not a rattle. I am sure I will get used to it in time and I hope it does lessen as it breaks in.
2014 FREIGHTLINER CASCADIA SLEEPER (A54313)
2014 FREIGHTLINER...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
23311 (A51694)
23311 (A51694)
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
1999 KENWORTH T800 DAY CAB (A54607)
1999 KENWORTH T800...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
