liberty2701
Platinum Member
Any experience with the !3KW Pto Gen. I think I can get one for a good deal? Is the power clean and is it built well? Thanks
Actually $1500 + shipping n tax.Looks like a new 13 KW surge NT brand generator is about $2400 with a two year warranty.
Id take the tractor over to it and hook it up and see if it runs right. then id drop that $500 cash in his had...:thumbsup:
I just got some more info on the unit. It is 4 years old never used. No carrier or shaft. I can get it for$550. Is this a good deal?
What a is a good place for a pto shaft? I see price variations from $100 to $300. Any length reccommendations?
Before buying a PTO drive shaft, I strongly suggest you measure the actual distance between your tractor's PTO and the implement's input stub shaft...at minimum distance (raise the implement...the shortest distance should be when the implement's input shaft and the tractor's output shaft are level with one another. That way, you'll know the minimum length you require...
your assuming the owner doesnt hard mount the genny to some location and simply back the tractor up to it. At which point you can position the tractor at any point to make use of an existing PTO shaft you have from say a brush hog.
...:confused2:That's not necessarily true. Think about it.
Implements are quite different when it comes to gearbox position.
Now, it the implement (genny, in this case), is not to be rigged to the 3PH, I can see the use of another implement's PTO drive shaft.
However, I doubt this would be the case with most generator owners.
...:confused2:
Yes, implement end fit is the point as stated. Broadcast seeders, manure spreaders, chippers, etc come with splined ends fairly uniformly. I use my broadcast spreader shaft on a 3pt carrier for that gen. Its light duty ... had to put needle cups into the u-joints. I also start the gen gently both to spare its 1 to 7 gearbox and avoid possibly twisting the light duty shaft.the owner might fid it hard to strip the pto shaft off his mower to use on that northstar ptogenset.. as it has a splined imput shaft same as the tractor stub.. IE.. 1 3/8" 6 spline.
most mower gearboxes are round input shafts. even some of the add on torque limiters are round, just because they are anticipating being added to a mower with a round input shaft. a few machine with torque limiters haowever, I have seen with splined input shafts. those pto shafts might be swapable..
best for the owner to see what he has before he thinks about swapping or buying..
soundguy
soundguy
