nortrac dozer trouble
   / nortrac dozer trouble #41
I didn't resurface the fly wheel, do you think it will be an issue?
If in fact there are little "cracks" in it, known as heat checks, then yes, it could be a real problem depending on how deep they are. They indicate a lot of heat build up either from slipping/riding the clutch or a frozen pilot bearing. But maybe I was just seeing things.:)
I do see the same thing you mentioned in the photo, I believe it was more crud then heat though. I did take the flywheel off and look it over as best I could, couldn't find anything that caused alarm. I did not use a magnifying glass or anything like that, maybe I should have?
   / nortrac dozer trouble #43
I belive you are probably OK then. If you would have needed a magnifying glass to see the heat checks, then they wouldn't be a concern. I usually check the runout of a flywheel with a dial indicator to determine if more than just a face cut is required.
Good job! :thumbsup:
:dance1: :drink: :cool2: :cloud9: :D Got everything back together and running, drove it around a bit to make sure everything was good. I then drove it over for some fuel and grease to get ready to put it to work. I hooked up my trailer and loaded 10 logs {8-14diameter by 8.5 to 14.5 feet long} everything worked great. The dozer pulled fine and the clutch worked better then ever.
Thanks again to everyone that helped :)
   / nortrac dozer trouble #45
Thanks for the follow-up with the final resolution! Now I can sleep soundly tonight.:laughing:
   / nortrac dozer trouble #46
Good job getting her fixed.
Chris
   / nortrac dozer trouble #47
Glad it worked out and it's fixed :thumbsup:
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A51691)
2024 Wanco...
2016 JLG 2032ES Electric Scissor Lift, 369hrs (A52384)
2016 JLG 2032ES...
UNUSED Black Steel Diamond Plate Sheet Metal (A53117)
UNUSED Black Steel...
2018 Forest River Grey Wolf 26RR Lmtd Toy Hauler (A52384)
2018 Forest River...
2012 Nissan Maxima Sedan (A51694)
2012 Nissan Maxima...
2002 CHEVROLET EXPRESS CARGO VAN (A53426)
2002 CHEVROLET...
