Oil Change Mess
   / Oil Change Mess #12
I use the extractors regularly mostly on marine engines and they don't work very well with cold oil, but 45 min for 3 quarts dose not sound right at all
   / Oil Change Mess #13
Or bend a little piece of sheet metal in a vee that you can wedge up on top of the offending cross bar while it is draining. That's what I do when draining the outboard rear axle housings on my Kubota. Just the cheap in me I guess.
- Jay
Even a good grade of cardboard works the same way.. It only has to last one oil change.:)
   / Oil Change Mess #14
Or some of your wife's aluminum foil can make a handy custom funnel / oil flow diverter. And the bonus is you can aggravate your wife by stealing her aluminum foil and not putting it back where you found it.
   / Oil Change Mess #15
I believe that would work!:)
   / Oil Change Mess #16
I know its not completely the same, but changing oil filter on my Harley does the same thing.. makes a big mess. I use the side from a half gallon milk bottle.. makes a great diverter and lasts quite a few changes. Experiment with how you cut it to fit till you find the right size shape.
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
2016 Ranger 570 EFI (A52384)
2016 Ranger 570...
2010 CHEVROLET SILVERADO 1500 (A53843)
2010 CHEVROLET...
