OK, How About B7500 vs. B2410?
   / OK, How About B7500 vs. B2410? #41
Re: looking long and hard at a B7500
Campster,
Welcome to the TBN!
Based on your description of your lot, the B7500 sounds like a good fit. What's your driveway like, and how long is it? If it's rock or gravel, you might consider a large unit.
<font color=blue>Anybody got a 4-way bucket on these little guys?</font color=blue>
Not that I know of, but stick around here & somebody will chime in. Start a new thread to get the most exposure.
<font color=blue>Want to be able to put it in the pickup truck bed--am I dreaming?</font color=blue>
Not at all. That's one of the things that turned me on about the B7500. A friend has a B7100 (almost the same as the B7500) that he hauls around in the back of his pickemup. Pretty neat settup. The FEL lays down on the rack above the cab, and the backblade "just" hangs out the back. A couple of tie downs, and he's good to go!
This would be impossible with any of the bigger B series because of the length.
The GlueGuy
   / OK, How About B7500 vs. B2410? #42
Seems there is almost universal acclaim in the contractor community here for the B20/B21. One rental house here in town has a B20 they let for $180/day with the hoe. Not bad considering the one near our place gets $190/day for a JD 30-horse with loader alone. Unfortunately, no implements at the place that has the B20 or I could try it out.
My ideal fantasy would be to buy the B21 with implements and then find somewhere I could rent the BT751 for the 5-10 days a year I need it. Even assuming I could find that arrangemment, the PTO HP is quite limited on the B20 (13.5) versus the 16-17 on the 7500. What will that impose on me in terms of limits?
   / OK, How About B7500 vs. B2410? #43
Rich, I would get the 60 inch deck over the 54. You have power to spare with either but the 60 sticks out more and allows you to cut in close and around trees and stuff more easily--yes it does. It is also 9 guage steel and the 54 is 10 guage. Hey, this weekend I moved and spread 15 tons of limestone gravel for the drive, another 5 tons of larger rock for erosion control and 30 tons of dirt for me and my John Deere neighbor and my Craftsman neighbors. All that with a little BX. I also am planning to use the FEL to rock two 2000 lbs. boulders back so I can get a skid under them to move them to their new spot. I will pull them with the BX and if it cannot then my Toyota will easily in 4LOW. Oh, hey, I mow a trail with my BX in the woods for my Collies and wife and neighbors to walk on. It passes down the back and corner of our properties. It has small sapplings that try to stick up now and then and it is rough and even soft in places--BX does that too. A brushog would be better, I am looking at getting one soon. I made the trail twist and turn and double back on itself to fool the dogs into thinking it was longer than it really is. I have it so tight in places a larger tractor would not be able to manuver. They love it. The boxblade tilted full forward and used in reverse is a great mini-dozer for pushing and spreading the rock. J
   / OK, How About B7500 vs. B2410? #44
Re: BX Boulder Mover
Trescrows writes
<font color=blue>I also am planning to use the FEL to rock two 2000 lbs. boulders back so I can get a skid under them to move them to their new spot. I will pull them with the BX ..... </font color=blue>
PICTURES!!!
I'm not going to say that it can't be done but be mindfull that you are definately exceeding the trailer loading weight.
Hate to see your little Bamm Bamm headed to the shop for repairs!
We're all in this together! (3)
   / OK, How About B7500 vs. B2410? #45
Dave; Was thinking along the same lines. If the object weighs 2,000 pounds, then that would require slightly over 2,000 lbs of force to get it moving, if the object was on a trailer, flat ground, with zero friction (perfect bearings). Not that I am saying it's impossible to move that (never say never, but I wouldn't want my BX to be the guinea pig), but dependent on skid, soil condition, and if there are any inclines during passage, the resistance should be significantly higher than 1 ton.
On other subjects, looked at your homepage yesterday. Nice pictures of the tractor, your 'helper' Frankie, and your wife.... But no pictures of Dave? You can't be that disgusting looking, can you?
Do you ship the honey, and of what nectars are they formed? Love fresh honey, and I am envious. I took an entomology course in college (1973 or '74), Beekeeping; fell in love with the idea. When I went home that summer, I told my parents that I wanted to rise a hive. They laughed. Problem was, we lived in Baltimore City.
Roy
   / OK, How About B7500 vs. B2410? #46
Roy, if I understood your logic it is flawed. It does not take 2000 lbs of force to move a 2000 lbs boulder. If it did then why is it I can put my 5000 lb Tundra in neutral and push it all by my lonesome! It is my intention to use the BX FEL under one corner to rock the boulders up so I can get another larger lever or timber under them and then each time I rock it using the FEL I will get a larger timber under until the boulder is high enough to skid them off the timbers on to a skid I will build. With the FEL bucket on the ground you would be surprised at the force it generates as a lever when it is commanded to bucket roll back. Since the weight of the boulder is 2000 lbs total but weight at the end lifted by the FEL will be much less, with 950 lbs breakout force appplied, it should rock the boulder back enough each time to get the larger and larger timbers under it---like a see-saw. As to towing it, tractors are for pulling and the tow weight limit has to do with many things other than transmission strength like controllability with a moving load, the worst that will happen would be all four wheels will loose traction and spin. In any case I will, if the BX cannot move it on the skid, use my little Toyota 4X4 truck, if it cannot and that is doubtfull it would not be able to, then I will bring in the Tundra, 4X4 and 5000 lbs of truck in 4low range with a 7000 lbs tow rating, should have no problem. Ah, give me a lever large enough and I can move the world and so can a BX. When brute force is not available think smart, the ancient Egyptions did the same method. J
   / OK, How About B7500 vs. B2410? #47
Why are you wasting precious diesel fuel moving a small 2000 lb rock? I just watched a program on how they estimate the natives moved the 20-40 ton statues on Easter Island using levers and people power. Just get your neighbors together. Don't risk scratching any paint off that loader! /w3tcompact/icons/wink.gif
Have to get lots of small tree poles/limbs and each time you rock it have your partner slip another one under neath. They say that's probably how those big statues were moved. I figured they pushed them in to a hole and then excavated around them! They still haven't figured how they put the 5-10 ton hats on top of them! Aliens? Ancient Alien Visit Bring Cranes?
Actually I would think that big a chunk could do a BX in, transmission wise. No neighbors around with a something bigger around?
del
   / OK, How About B7500 vs. B2410? #48
J,
Now you've got me confused! /w3tcompact/icons/blush.gif
Did the Egyptians use the BX, the Toyota, or the Tundra??
/w3tcompact/icons/laugh.gif
Larry
   / OK, How About B7500 vs. B2410? #49
Del and Larry, my neighbors are good at getting me to help them but are scarce when I need them--lol. Sooo, my BX will be my partner and we will do it very much like you said to move the rocks. As to if the ancient Egyptions had a BX or a Tundra your guess is as good as mine, I suspect their alien buddys may have supplied both! Hey, ya gotta scratch the paint on the loader--good grief! J
   / OK, How About B7500 vs. B2410? #50
Any good ancient Egyptian mechanical engineer will tell you that the force that is required to start that rock moving on a horizontal surface is equal to the normal force (or weight in this case) multiplied by the coefficient of static friction (who the heck knows what that is in this case) between the rock and the ground, or skids and the ground, etc. A typical value for the coefficient of friction in engineering cases is 0.1 to 0.25, but the number can be much greater than 1.
Trailer towing ratings are a little misleading since they're probably based on rolling resistance and other things like brake capacity - what's needed is a rated trailer weight for when the trailer brakes are locked up, the tires are flat, and you are on dirt/w3tcompact/icons/smile.gif.
TresCrows - any concern with putting a ripple in the bucket of your BX? I've got some rocks I have my eye on too, but I wasn't sure how much prying the lip would take.
2020 UNVERFERTH 332 LOT IDENTIFIER 187 (A53084)
2020 UNVERFERTH...
2019 Caterpillar 950M Articulated Wheel Loader (A51691)
2019 Caterpillar...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A51248)
UNUSED FUTURE SB45...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
UNUSED AGT TSOCPF48 MAST W/ 48" FORKS (A51248)
UNUSED AGT...
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
