Old Cultipacker
/ Old Cultipacker #1
FarmerCharlie
Auburn, AL
JD 2130 and 1020
Can anyone identify this old cultipacker? The rear wheels are 9" diameter. I understand that at one time it had a seeder attachment, and I'm wondering if it would be practical to add a seeder box. It's also missing one of the rear rollers, which I would like to replace.
/ Old Cultipacker #3
I wish I could find one like that. I want to cut one down to pull behind my two bottom plow.
/ Old Cultipacker #4
From the looks of the hitch it may be from the horse drawn era.
It looks perfect to me if I wonded it. I would grease and go unless you plan to use it to do 10,000 acres. :thumbsup:
Typically these things stay parked 99.99999% of the time and get used at seeding time. :D
/ Old Cultipacker #5
Thats a dandy look'n packer...:cool: Sweettractors should be able to identify it. To me, it looks like an old deering design almost. Too bad its lacking a seed box but, very useful still:D
/ Old Cultipacker
It's on a kind of indefinite loan from a friend of mine. I use it for sowing grass and summer annuals. Disk it, smooth it with a homemade tire harrow, seed it with a Baltic spreader, and then run the cultipacker over it. I wind up with a pretty smooth turf. But it does take four passes over the field to get all this done. My next project is getting some native warm season grasses started, but I'm not sure if I can handle the fluffy seed with my spreader.
/ Old Cultipacker #7
I would say Dunham or Brillion. I does appear to me the frame has been modified, looks a little strange.
/ Old Cultipacker #8
The "parts" look like my McCormick, just put together differently. It's definitely been modified.
You sure about that? I can't see any way that would work well.
/ Old Cultipacker #9
You said the small back wheels are 9 inch diameter. Most double rollers have 15 inch front wheels and 11 inch back wheels. Sweet Tractor and Leinbach Equipment have old cultipacker wheels they sell. I believe they are about $35
/ Old Cultipacker #10
From your second pic it looks like wood blocks the axles sit in? And grease zerks on top? Seems like a pretty cool setup.
Jim
(7) 2000 LB TRAILER JACKS & (5) JACK TURN HANDLES (A64280)
(7) 2000 LB...
2011 John Deere 5085 70HP Utility Tractor (A60352)
2011 John Deere...
75 TON IRON WORKER (A64280)
75 TON IRON WORKER...
2004 COMBILIFT CL30060LA45 FORKLIFT (A63276)
2004 COMBILIFT...
2025 Rippa IREAS Ripper Mini Excavator Attachment (A61572)
2025 Rippa IREAS...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
