Old Toro Reelmaster Project
   / Old Toro Reelmaster Project #51
There is something you are not considering, and that is, that I believe those hyd motors were selected to run at about 1400 rpm. If he now doubles the pump flow through the three motors, the rpm will about double to about 2800 rpm. I think the final outcome will be blown motors, whereas the motors could could be used in another project while they are intact and food. . I believe I would select hyd motors for the flow that you have that will give the torque required.
I have suggested a flow control valve to limit the flow. That is what I use on my PTO circuit for any of the hyd implement I use. Auger, tiler, etc.
If the one motor test mower were to stall, the motor relief would limit the pressure to 1500 psi.
2018 CATERPILLAR 259D SKID STEER (A60429)
2018 CATERPILLAR...
2012 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A59904)
2012 FREIGHTLINER...
2006 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A59575)
2006 INTERNATIONAL...
20.7kW Aptos 440W w/ IQ8PLUS Enphase Microinverter Solar System (A59228)
20.7kW Aptos 440W...
Quick Attach Adjustable Forks (A59814)
Quick Attach...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
