Oliver Super 77 Hydraulic Pump gasket(s)...
   / Oliver Super 77 Hydraulic Pump gasket(s)... #1
dmsims69
John Deere 2305
I am installing a rebuilt hydraulic pump into an Oliver Super 77 (it's been removed for years). I am attaching pics of the pump and where it mounts. My question is if this takes a gasket or not?? Also, does anyone know where I can get gaskets for the "cover" plate or do i need to use some RTV instead??
   / Oliver Super 77 Hydraulic Pump gasket(s)... #2
Orings for the pump. You can see the machining around the ports for orings. Make a paper gasket or you might ask: Oliver Parts for Tractors
Oh, yeah, I see that now..thanks! I will have to figure out the size, but not difficult. I'll also look at getting gasket material if I can't find any premade.
Just an FYI... I was able to locate a supplier who has the gaskets and o-rings. Check out Korves Oliver
Chemical Containers Tank (A57148)
Chemical...
(18) 10'-6" PVC CONDUIT PIPE (A60432)
(18) 10'-6" PVC...
Rotating Brush Sweeper Tractor Attachment (A59228)
Rotating Brush...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A61306)
Bulk Lot of NEW...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
UNUSED FUTURE FTH50-(50)SHEETS OFGALVALUME (A60432)
UNUSED FUTURE...
