OMG, Just can't decide on a tractor
   / OMG, Just can't decide on a tractor #1
bowpro12
Buffalo Gap, Tx
Kubota 3800 HST
I'm in the market for a 35-38 hp compact tractor. I started off with JD, Kubota, Kioti and Mahindra in the running. All because I have local dealers and support.
Must have or capable of:
Compact size
Hydrostatic tranny
Have or capable of single hand, third function for grapple bucket
Foldable ROPs
Maximum warranty
Gross vehicle weight less than 5.5k with loader and box blade
I've ruled out the JD 38E because of the difficulty in obtaining third function capabilities, flimsy plastic hood, non foldable ROPs and Couple other misc items.
Remaining are the Kioti CK35 HST, Kubota 3800HST, and Mahindra 3616HST
My remaining filters will include:
Warranty- Mahindra, Kioti, Kub
Horsepower- Kub, Mah, Kioti
Lift capacity- Kub, Mah, Kioti
Dealer Support- Kub, Mah, Kioti
Price- Kioti, Kub, Mah
Overall weight- Kioti, Kub, Mah
If my research is correct, the Kubota comes out with 3 first places, 2 seconds and a last on the most important filter.
Will I go horribly wrong with the Kubota?
Primary I use will be Brush clearing with grapple bucket, shredding and dirt moving, leveling etc.
   / OMG, Just can't decide on a tractor #2
Looks like your research may be off on the loader specs. The Kioti loader is spec'd at 1151 to full height at the pins, and the Kubota 1121 to full height at the pins.
I don't think you can really go wrong with any of the three, but make sure you do a couple of things before getting to set on what to buy. One, try to compare apples-to-apples as far as the setup goes....i.e. the same number of remotes, quick attach for the FEL, telescoping lift arms, etc, etc...all the little things add up. You can't really compare prices if you aren't looking at similar options. Two, get hard quotes from dealers, not the online builder programs. Third, go sit on all of them, and run them as much as possible. Things that don't matter to me might really annoy you, or vice-versa.
Something that seems to happen regularly, is that people think they know which tractor they're going to like best, but wind up liking something else better, because of one or two little details that they can't overlook...that causes them to second-guess themselves. With big names like you're comparing, they all make a decent machine....you really can't go too far wrong with any of them.
   / OMG, Just can't decide on a tractor #3
Wow. It must be early because there is no budget listed and Gman didn't give any LS tractor specs. I'll assume you're looking for a cheap tractor if you aren't considering the deere 3520 or it's 2014 R replacement. You should at least look at one because they come with a really nice third function loader handle with an integrated button. The deere also has Ehydro, another nice feature.
   / OMG, Just can't decide on a tractor #4
Good research, I do go through same process buying implements, using a spreadsheet. I like to calculate dollars/pound too.
As a retired marketing guy I have to comment: "Anticipation is half of Satisfaction".
If you end up at a tie, two way, or three way, I would make how you feel about the brand dealer the tie-breaker. I had a lot of questions for my dealer during the first two months. Had I known about T-B-N at the time I could have asked some questions, not all, here.
Do not calculate your weight max including implements. Calculate weight just on tractor. Whether you order default R3/Industrial Tires or R1/Ag Tires, or Turf Tires will make a slight difference in ground compaction.
However, maybe this is a trailer loading consideration??
   / OMG, Just can't decide on a tractor #5
There's no need for that sort of comment. I don't do something you dislike, and you're going to go out of your way to bust my chops? Nice. He didn't ask about any other brands, or possible alternatives, and he already said why he's looking at those three brands (local dealers and support), so there's really nothing to add. He already has a good cross-section in those three brands.
He's not looking at a Deere, so you're going to insult the guy and say he's looking for a cheap tractor? Wow...classy. Actually, he already said why he looked at the three brands listed...local dealers, and support.
After all of that, I'd still load up my "cheap" LS or Massey, and come pull that toy of yours out when it gets stuck :thumbsup:
   / OMG, Just can't decide on a tractor #6
The 1026 is a Lawnmower compared to what he's asking about. If you buy the Kubota make sure you try the tractor your buying with a very heavy implement on the 3 point to see if it is smooth enough for you.
   / OMG, Just can't decide on a tractor #7
I can't do any better than to agree with GManBart, all are good and small differences like extendable lift links on 3PH, remotes, available options count and don't forget ergonomics.
I do believe in research and do a lot of it before buying, but have on more than one occasion bought a different tractor than the one that looked better on paper.
I have found also that it takes more than a few minutes on the lot to get a real "feel" for the machine though it can help a lot.
   / OMG, Just can't decide on a tractor #8
...differences like extendable lift links on 3PH
Especially for a first time tractor buyer, maybe THIS should be the tie-breaker.
   / OMG, Just can't decide on a tractor #9
Compact size
Hydrostatic tranny
Foldable ROPs
Maximum warranty
Looks like you have a pretty good choice of good tractors. I looked at Mahindras when I bought my tractor and didn't find the fit and finish that great AND the red paint fades to a breast cancer PINK in a few years of sun exposure. Some of the Kubota's with 1/4 inching valve end up with a jerky 3 point lift so watch that on you Kubota tractor. I haven't really heard any repeat negatives on Kioti tractors from owners. All tractors have the occasional glitch that causes some warranty issues. I think most Kubota's only have a one year warranty so that would be the least of any of the other two I think.
If you intend to do dirt leveling, be sure to get a good box blade, FEL's aren't meant to do heavy digging as a stand alone implement. Soil needs to be loosened up first.
I think what your are going to condense it down to will be price and warranty as everything else on these is going to be nearly the same.
Since GManBart didn't mention LS tractors, I will. Go look at one prior to making your final decision.
   / OMG, Just can't decide on a tractor #10
My thing would be What dealers are within 50 miles of you?
Outstanding comments so far. I really appreciate the help.
The comparisons are difficult for sure, it seems like there should be an industry standard. Each manufacturer kind of camoflages there specifications, especially on the loader lift specs.
A few things that I left out are my budget (23K including impliments - loader, grapple, box, and shredder), desire for a "new" tractor for warranty purposes and weight limit to match my existing trailer
capacity.
I have certainly learned a tremendous amount through research here and the web. Most importantly, in the seats of of all four. Had I not driven them, I certainly would have bought the JD 38E and been pleased untill discovering the difficulty in third function modifications, two spead tranny and all the plastic.
Next is the Kubota. Meets all my criteria and will certainly do everything I need. About the only thing this unit does not have is the extendable hook-ups. Price $21,450 (tractor, loader, third function, 6' HD box' 6' HD shredder, grapple).
The Kioti was an eye opener. Never knew about the extendable hook-ups and all. This tractor too will do everything I want as far as I know. My only hang up on this tractor is the jerky controls for rear lift and the dealer is 20 miles away rather than 8 miles for Kubota. Also, dealer was not a fan of HST and tried his best to talk me out of it. Service priority was probably the best of the three dealers. Better warranty than Kubota too Price is $19,795 ( similar impliments, basically less warranty).
The Mahindra dealer just was not real interested in selling me a tractor. Took him a looong time to call me back and tried to sell me a tractor out of my budget.
I think it boils down to the Kubota being about 1K higher ( considering the higher quality impliments), but closer to me for dealer support. My stress level goes up with the Kioti. It is an awesome tractor, better warranty, more of a small town one on one feel with dealer and 1K cheaper.
Last comment - my "GUT Feeling" is to go Kubota?
   / OMG, Just can't decide on a tractor #12
On the warranty, I have heard many folks get the Kubota insurance that covers a bunch of stuff. I don't have it, but have heard good things about it. It might fill the gap perhaps.
   / OMG, Just can't decide on a tractor #13
The plastic used on JDs isn't really "cheap". It's just a different way of doing things.
It won't dent or rust, for example. But it would break if hit hard enough, whereas the steel on the others won't.
   / OMG, Just can't decide on a tractor #14
I am obviously a fan of Kubotas, certain models at least, but recognize others make good machines. I would have the dealer put the rotary cutter on the 3PH on the Kubota and Kioti then check the lift out at all speeds including very slow as some have reported a jerky hitch on the Kubota Lxx00.
I personally have never worried much about warranty, but it is important to some, only you can decide. My dealer is about forty miles away and we do all our own maintenance.
The good thing is, either will make you a pretty happy guy.
Oh no! Just checked out the LS R3039H. This tractor certainly has merits. Looks like another rack and stack comparison.
Thanks guys!
   / OMG, Just can't decide on a tractor #16
Thanks guys!
Oh no...now you've gone and done it! :eek:
   / OMG, Just can't decide on a tractor #17
bowpro12,
No one can say that you did not do your research.
   / OMG, Just can't decide on a tractor #18
Excellent post Bart!
   / OMG, Just can't decide on a tractor #19
My only advise is after all is said and done and you have made your 1,2,3 rankings, go try one out...
You may not like how the tractor fits you...
I am not that tall but my left leg rubs one of the control levers on my 1720...
The tractor was used when I bought it and it has been flawless...
If I was buying new I would make sure that the next tractor was a little bit wider in the operator station platform...
Otherwise I love my unit...
   / OMG, Just can't decide on a tractor #20
Good advice has been given here. Many people plan to keep their equipment for a long time and that brings up another couple things to think about. First, a difference of 10 or 20% in price may seem a lot at the time of purchase, but spread over ten years or more, it really isn't all that much, so your main criteria should involve which equipment you personally like the best. Also for the same reason, try to choose equipment that comfortably handles the majority of the work you anticipate. If you go too small, both you and the equipment will be constantly struggling to keep up.
UNUSED FUTURE EXCAVATOR COUPLER (A60432)
UNUSED FUTURE...
UNUSED 2026 INDUSTRIAS AMERICA HYD TITL TRAILER (A60430)
UNUSED 2026...
(INOP) TAKEUCHI TL12V2 SKID STEER (A60429)
(INOP) TAKEUCHI...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
KIVEL 48" PALLET FORKS 3500 LB CAP (A60430)
KIVEL 48" PALLET...
UNUSED IRANCH MINI EXCAVATOR QUICK COUPLER (A60432)
UNUSED IRANCH MINI...
