Only in Texas, Don and Harv doing
   / Only in Texas, Don and Harv doing #291
Don & Karen are about 13 miles from my place -- anytime except Oct 14-15 is good with me---- We'll be in Canada for a grandson's B'day -- Don - I should be able to help with setup. BUT --- (no pressure here) -- You better hustle and git 'er done.:)
   / Only in Texas, Don and Harv doing #292
Mike, Unfortunately or fortunately, I work best under pressure.
RonJHall said he plans on being in TEXAS the end of October/beginning of November. If I could just convince him to trade places in August.......:D (no one tell him about the heat).
   / Only in Texas, Don and Harv doing #293
Ron & Betty have to be in Ft. Worth the last weekend of October. Margaret & I don't have anything scheduled for any other weekend of October.
   / Only in Texas, Don and Harv doing #294
That's it! We all get in costume and go trick-or-treatin' down at Don's. YIPEE! This is gonna be fun.:D :D :D
Just kiddin'.... But as I remember, we "Fall back" sometime the last weekend of October, so there will be a shift in daylight time.
Except for making plans on meeting up with Ron and Betty, Kathy and I should be available; although, there is a possibility her aunt and uncle from Kentucky might be coming around that time also. We'll go with the flow...:)
   / Only in Texas, Don and Harv doing #295
Don, I'm sure enjoying watching your progress. Keep the pictures coming.
Most any weekend is good with me.
Harvey, my retiree turned college chick said she would be happy to taxi. :D I'm still good with the college thing until she comes home looking like a tatoo'ed pin cooshen, like some of her class mates. :eek: Only problem might be our son has some band competitions in Oct. Dates are TBD. So ya'll pick the date and she will try to be there.
Harvey, have used your plasma cutter to cut tin? I used mine the other day to cut some scrap U panel and it looked pretty good. I think it would work o.k. any place the tin was covered by trim. Need an expert opinion.
James
   / Only in Texas, Don and Harv doing #296
I'm OK with any 2nd or 4th weekend. I'll be coming from N. of Greenville.
We (Glenda, Scott, and myself) have looked at our schedules and it appears every weekend is locked up until the end of October. Which might work out alright and it might not for others.
James, I've used the plasma to cut the R panels since I got mine. It works great. The only hiccup is cross cutting and keeping the cut straight. Of course the big advantage of the plasma over the torch is you can pause and not increase the damage to surrounding material. The faster you move the less burn line you have, a sixteenth of an inch or less isn't unusual when the ducks don't mind lining up. But if they're in a flocking mood, well, you know.
   / Only in Texas, Don and Harv doing #298
We are leaving on or around the 21st. Being retired like some others we have not finalized our schedule. :rolleyes:
May have do some trick or treating in Sunset TX. :eek:
Our schedule is open except for the 29th. Granddaughter will have a busy day getting signed in and attending meetings. So not showing up until that evening will not hurt our plans.
It will be great to attend another TBN get together in TX. :cool:
Want to see Harvey's pole barn system. Need a storage building for the Motorhome. :D
   / Only in Texas, Don and Harv doing #299
OK then, the date for the party will be October 28, 2006.
The first entertainment segment will be cheering Ron and Betty as shift their motorhome into 4 wheel drive and try to make it up the sand hill through the grape vines and trees. This will be fun.:D
   / Only in Texas, Don and Harv doing #300
4 wheel drive??? I wasn't planning on bringing the tractor. :D
2006 CATERPILLAR 330DL EXCAVATOR (A51242)
2006 CATERPILLAR...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A50322)
2018 John Deere...
2019 NEW HOLLAND TS6.130 TRACTOR (A51406)
2019 NEW HOLLAND...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2024 AGT INDUSTRIAL QHT-500FL CONCRETE BUGGY (A51243)
2024 AGT...
Case 580D (A47384)
Case 580D (A47384)
