Only in Texas, Don and Harv doing
   / Only in Texas, Don and Harv doing
I explained to Don that I formed up the beam first. Then I decided where I wanted the water and electrical to come in to the building.
I cut two pieces of pvc at an angle and then drove them into the ground about a foot. This made it easier in this situation than digging out a cavity, roughing in the plumbing, and then filling the cavity for forming and pouring the beam.
Then I cut off the angle cuts and took off with the plumbing and electrical conduit.
This is in the county way out in the country. But I personally don't like water and electrical in the same trench. I ran the electrical about thirty inches deep and the water about eighteen.
A couple of years ago I put an auger through power and water at the same time. It was about a foot deep with direct buried romex and that black water tubing that comes in big coils. What made it extremely interesting was the electrical wasn't on a breaker and straight off the meter. /forums/images/graemlins/blush.gif
The auger came out of the hole automatically when it heard what sounded like a gunshot. I found the tap and cut it hot with bolt cutters. It's no fun hitting water and power at the same time.
   / Only in Texas, Don and Harv doing #162
Electrical:
Here is where I need help.
I will be connecting the carport/storage area to the cabin's electrical service.
The cabin has a 200 amp service breaker box.
The distance from the cabins box to the carport/storage area box will be 110'.
I want to be able to run my Miller MIG welder which runs on 20 amps.
Where I will be digging is also the walking path so I also want to run the electrical for lighting the path. The carport's door is 90' from the cabins porch. I would like to be able to turn on the lit path at either end. I also would like to be able to turn the lights on in the carport from the vehicle (I like to see the snakes before they see me).
I'm thinking a 50 amp breaker box in the storage area.
What size wire do I need? I will be installing it in PVC.
Any suggestions on the proposed electrical run?
   / Only in Texas, Don and Harv doing #163
Electrical:
   / Only in Texas, Don and Harv doing #164
Don, I am not a licensed electrician only an opinion.
I would run 4ga wire off a dual 50amp breaker to another 50amp breaker box.
   / Only in Texas, Don and Harv doing #165
Here's a great link that someone on a welding site gave us.
http://www.elec-toolbox.com/calculators/voltdrop.htm
Here's why we do the ledge on the slab and beam. It not only helps seal the bottom of the building. It's a safety item when you consider the damage siding can do to a horse. This is a stall door to an outside paddock.
The horse barn is coming together.
One of the things we do is put on the sheeting for the roof on the roof.
Here's four of us up there.
John Deere 506 3 pt Mower (A50515)
John Deere 506 3...
20' Inline Feed Bunk (A50515)
20' Inline Feed...
UNUSED CFG Industrial MY50R Mini Excavator (A47384)
UNUSED CFG...
UNUSED FUTURE 7T HYD THUMB CLAMP (A51244)
UNUSED FUTURE 7T...
2019 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2019 Ford F-450...
2016 Nissan pathfinder (A50324)
2016 Nissan...
